Originally Posted by Marco620
Seems Castrol is the go to ATF for Honda. Their Transmax series is top notch.Much better quality and value than Valvoline too.
Castrol "Transmax" Import Multi Vehicle ATF is a a good value fluid and performs with very similar results (shift quality, shift points at RPMs)
to OEM Honda Z-1 and Honda DW-1. I want the fluid to behave as closely as possible to Honda OEM because you probably have the best chance of getting the longest life and best performance from the transmission.
