Originally Posted by kschachn
Pour point is not a reliable indicator of cold-weather cranking performance, the 0W rated oil will be better at very low temperatures. As you note, below -25F or even colder. Up until then there's really no way to predict which one might be slightly better.
Right, i get that. But mfgs don't always publish mrv (as previously stated) so you get what you get. You base your decision on whatever you have to work with and if all you have to work off is pour point, well pour point it is. It's better than nothing/guessing.
Both the 5w20 and 0w20 are likely using similar Grp4/5 base stocks (maybe some grp3 for "cheaper" 0wX brands??), the difference (I'm guessing here) is going to be in the amount of VII's. Since VII's are a non starter at low temps (correct??), can we surmise that the cold flow characteristics will be very similar up to the very extreme end of the scale (-below -30/35c??)
