Current Honda Factory Fill
by asiancivicmaniac - 12/09/19 04:16 AM
Gulf Western - Premium Gold 15W40
by SR5 - 12/09/19 03:43 AM
how can one tell 100% that the oil was changed
by WhyMe - 12/09/19 03:22 AM
Scraped the side of my truck...
by GumbyJarvis - 12/09/19 12:44 AM
Outlasted 3 Marriages
by Y_K - 12/08/19 10:10 PM
High miles on 0W20 oils?
by EyesofThunder - 12/08/19 10:02 PM
90 350 intake gaskets and sealant
by P10crew - 12/08/19 10:01 PM
Glock Polymer80
by pkunk - 12/08/19 09:59 PM
Reman steering rack 09 CRV
by Chester11 - 12/08/19 09:24 PM
Edge 5W-30 10k miles '13 F150 5.0
by dustyroads - 12/08/19 09:18 PM
Hyundai engine failures getting news again
by OVERKILL - 12/08/19 09:04 PM
2015 Ford Fiesta ST
by daemontrym - 12/08/19 07:39 PM
NVX NSP65 Speaker review: Good deal!
by 14Accent - 12/08/19 07:26 PM
Thanks to Quattro Pete for making the 2020 avatars!
by wwillson - 12/08/19 07:17 PM
Klotz 2 Stroke Smelling Candle
by FA_WRX - 12/08/19 06:31 PM
Non scientific oil test.
by tblt44 - 12/08/19 05:33 PM
Nitromethane prices
by 53' Stude - 12/08/19 05:31 PM
Question about JASO specs?
by frascati - 12/08/19 04:15 PM
Anyone knows outdoorsy magazine that are US only?
by MoneyJohn - 12/08/19 03:54 PM
redradar, Jonas_K, slxgold, Dennisfly, AutopartsTester8
70070 Registered Users
29 registered members (DaHen, asiancivicmaniac, Bama, Dave_Mark, alcyon, 4WD, 3 invisible), 661 guests, and 51 spiders.
Topics298,472
Posts5,136,098
Members70,070
Most Online3,589
Nov 2nd, 2019
2014 F150 3.5EB Tuned 5w-30 Pennzoil Platinum 4,100 miles #5173906 07/29/19 01:10 PM
covshark Offline OP
Attached is my 2nd UOA for my Tuned & 180 tstat F150. This go around had some mild to heavy towing between 3k lbs boat and a 6-7k lbs tractor and trailer. I've been attempting to stay between 4-5k on the oil changes, should i extend it out further?
I replaced the PP with Magnatec 5w-30. Will report back next UOA to see how the magnatec did.
Re: 2014 F150 3.5EB Tuned 5w-30 Pennzoil Platinum 4,100 miles [Re: covshark] #5173922 07/29/19 01:19 PM
U
UncleDave Offline
U
I wonder what % of that viscosity reduction is shearing, and what is dilution.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: 2014 F150 3.5EB Tuned 5w-30 Pennzoil Platinum 4,100 miles [Re: covshark] #5174176 07/29/19 05:51 PM
Z
ZZman Offline
Z
Really not liking how weak the newer PP add pack looks.
2007 Hyundai Santa Fe AWD.
2005 Toyota Avalon XLS
Re: 2014 F150 3.5EB Tuned 5w-30 Pennzoil Platinum 4,100 miles [Re: covshark] #5174671 07/30/19 08:37 AM
cdlamb Offline
I use the same PP 5W-30.
The oil analysis company I use flagged by Boron when it reached 130, at Lower Reportable, & Lower Critical when it was at 78 on my most recent oil change.
The Baseline Sample I sent in had these number in the additive pack.
Code
Moly         83
Boron       224
Calcium    1033
Magnesium   631
Phosphorous 604
Zinc        732
Maybe I can go further, my last sample wasn't showing much for dilution.
Re: 2014 F150 3.5EB Tuned 5w-30 Pennzoil Platinum 4,100 miles [Re: ZZman] #5174715 07/30/19 09:45 AM
B
Baveux Offline
B
Weak add pack ? I know nothing about add pack quality and performance, what to look for, whats important and not , however I use PP 5w30 in my 2014 eco f150 thinking it was a great option , now whats a better option ?
Re: 2014 F150 3.5EB Tuned 5w-30 Pennzoil Platinum 4,100 miles [Re: UncleDave] #5174883 07/30/19 01:01 PM
ChrisD46 Offline
UD
*Good question as PP 5W30 is at the lower end of a 30 weight (9.6 viscosity I believe) . In this example after 4,100 miles the viscosity is down to 8.7.
I never thought I would suggest PP 5W30 as my new "winter" oil ?
'17 Hyundai Sonata 2.4L GDI 5W20 QSUD / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Re: 2014 F150 3.5EB Tuned 5w-30 Pennzoil Platinum 4,100 miles [Re: ChrisD46] #5177074 08/01/19 09:46 PM
G
Garak Offline
G
All ILSAC 30s are fairly close to the low end of a 30 weight, particularly by HTHS.
Plain, simple Garak.
Re: 2014 F150 3.5EB Tuned 5w-30 Pennzoil Platinum 4,100 miles [Re: Garak] #5177796 08/02/19 07:21 PM
cdlamb Offline
& the earlier Ford 3.5 EcoBoost was designed to run on a 5W-20, so I don't think the dilution, unless it gets to bottom end of a 5W-20 shouldn't be a real serious issue.
Re: 2014 F150 3.5EB Tuned 5w-30 Pennzoil Platinum 4,100 miles [Re: Baveux] #5177924 08/03/19 12:30 AM
Z
ZZman Offline
Z
M1 HM, Amsoil, Pennzoil Ultra, Castrol products to name a few. all look to have stronger add packs from looking at the UOA's.
Re: 2014 F150 3.5EB Tuned 5w-30 Pennzoil Platinum 4,100 miles [Re: covshark] #5252177 10/28/19 01:44 PM
I
Impatient Offline
I
Covshark (OP): Looking forward to seeing your Magnatec UOA...assume it is latest SN+ version???
Regarding PP, wouldn’t you “feel” better if visc were higher, and TBN (judging from earlier UOA) was higher after a mere 4900 miles? IMHO, there is something about PP that some EB’s don’t like... and no I don’t feel better using a lab (Amsoil/Polaris) that truly tests for fuel dilution (because they show it actually does exist in my engine). Then again, maybe you don’t have that fuel issue...although something is causing you to end up with 5w20 oil (...even if “just barely” according to BStone). My visc was worse, and Ultra Plat did not appear to have really fixed that problem either.
Rotella Gas Truck? Or maybe the Magnatec. With any luck you’ll have another UOA before I have to decide.
15 Ford Transit 250 3.5EB Turbo
07 Subaru OBXT 2.5 Turbo Castrol Euro 0w30
Re: 2014 F150 3.5EB Tuned 5w-30 Pennzoil Platinum 4,100 miles [Re: covshark] #5279173 11/27/19 06:46 PM
covshark Offline OP
I've got about 5200 miles on the magnatec as of now. I'm taking a trip this Thanksgiving and will be changing the oil very shortly. A sample will be sent for analysis when the oil is changed.
I've been lucky and have picked up many quarts and 5 gallon jugs of rotella gas truck now that it's on sale for $2/quart. Castrol edge is going in next, then RGT after that.
Re: 2014 F150 3.5EB Tuned 5w-30 Pennzoil Platinum 4,100 miles [Re: covshark] #5279339 11/27/19 10:41 PM
N
nlife Offline
N
Looking forward to seeing the results. Has the Magnatec seen similar driving conditions as PP?
Re: 2014 F150 3.5EB Tuned 5w-30 Pennzoil Platinum 4,100 miles [Re: Baveux] #5284026 12/03/19 02:07 PM
R
Railrust Offline
R
I don't know if it's "better", but Rotella Gas Truck Synthetic has what looks like a pretty robust additive pack, supposedly tailored to trucks and suv's (not really buying that type of advertising, but). The moly is higher than PP. made by the same company, I believe. I'm sure the base stocks are not the same or anything, but the additives seem a bit higher in the Rotella.
Re: 2014 F150 3.5EB Tuned 5w-30 Pennzoil Platinum 4,100 miles [Re: Railrust] #5284479 12/03/19 09:33 PM
B
Baveux Offline
B
Thanks railrust ... Ill use my stash of PP and Ill look at the rotella :-)
