What scanners do you guys recommend for the DIY'er that supports a decent amount of live data. I have a Innova 3140d that only supports 26 PID's for my 98 chevy trucks and I have an older AutoXray 6000 that supports over 40 PID's.
I went to read what my cam retard reading was on my 98 K3500 because awhile back I discovered that my distributor bolt was loose and I accidentally moved my distributor while messing with the cap and just tried moving it back to where I thought it was. Since then my truck has not been starting very well, like it's firing between the distributor contacts.
I hook up the 3140d and it doesn't give me a reading for this or very much of anything. I then try my 6000 which is no longer made or supported and the company no longer exists and it does have this reading. As I suspected, the cam retard was out of spec at -3.2. I adjusted it to a -1.4 and called it good. The truck does start better now.
I want to upgrade to a newer scanner that will support more live data than the 3140d and will be able to read the cam retard on my 98 trucks.
Does anyone have any suggestions for a good diagnostic scanner and not just a basic code reader. I don't mind paying a little more for something that will give a decent amount of info for the trucks as well as for my Mustang. Thanks.
