Originally Posted by bubbatime
80's with no AC? No thanks. I keep my house at 71 degrees, my cars never come off full blast as cold as possible, and I usually have several fans circulating air in the house too.
I occasionally visit northern homes and they just bake in the heat of the summer inside without AC. So ungodly uncomfortable, and it makes zero, zero sense to me. A freaking AC unit is $100 at Walmart. Heck, I bought a window unit on clearance for $49 brand new.
In my personal opinion, you have to be some kind of stupid to not have AC in the summer.
I tried mastering the art of moving window fans around and failed found that it was a waste of time when it's hot out. The solar radiation added too much to the house to keep temps in the living room, for instance, comfortable, even if it was 78F outside (just making that number up for demonstration purposes). Add to that any sort of humidity and it was very uncomfortable.
Now, I don't even attempt ambient air circ unless one or more of the following conditions are met:
1. It's windy outside
2. It's in the low 70's F or cooler
3. Humidity is low
