Vehicle: 2012 Honda Odyssey Touring.
At 79K, the vehicle was overdue for a transmission service and due to budget reasons, Kendall VersaTrans LV was installed. The transmission was drained (3.75 quarts) and an additional 8 quarts was exchanged using the cooler lines. Total fluid used was 12 quarts. After the service, the transmission software was updated to the latest calibration and road tested. Shift quality was ok, but engagement was noticeably harsher than DW1.
At 94K, it was observed that the fluid was quite dark. The customer approved another transmission service. This time, 3 drain and refills were performed using Idemitsu Type H Plus. 3.7-3.9 qt each time, total of 11.5 quarts. After the "flush" with a Idemitsu, the shift quality was identical to other Honda 6AT's running DW-1. You can only hear the engine rpm changes, you cannot feel the shifts.
This is just one data point. I recognize that the Idemitsu Type H Plus uses a very different additive package than DW1, but from what I have observed, it shifts identically to the OE fluid. I cannot say the same for the VersaTrans LV product or other multi-vehicle fluids I have tried.
