Originally Posted by RayCJ
Originally Posted by Eddie
+1. A diamond faced rotary wheel might be the only way. I suspect that the hardened surface is only a few thousands thick, so that precludes any resurfacing. Ed
Finally got around to reading the whole article... The coating (Tungsten Carbide) is 100 micrometers thick (translates to 0.00394 inch) so yeah, about 4 thou (0.0001 mm) thick. The article wasn't perfectly clear but, it's applied in a heat deposition process that sounded similar to arc spray transfer. It later mentions that the pads eventually polish the surface like a mirror and the rotors will have about 30% more service life vs cast iron. And finally, it requires special pads to be effective.
I'm curious about service cost and wonder how the economics play out for non professional race team (i.e. consumer) applications.
Ray
If the rotors only last 30% longer than cast iron, I don't see it being cost-effective. The coating probably adds more than 30% cost to the rotor, and having special pads only makes the system more expensive. GM probably gets a bigger improvement in rotor life with their nitriding process.
