I use it in everything. Just used it in my '04 Lexus ES 330. I put a new radiator and thermostat (they were bad). What drained out was weak, dirty pink, or red, probably original, but the internals looked like new. I flushed it 4 or 6 times with distilled water, then poured in Prestone concentrate. I know enough to not use coolant with silicates, but other than that what's the fear? I mean, I'll change it in a couple of years, probably only 5,000 on it by then. So far it survived a hot trip to New York City, no problems as expected of course. What's the risk with using the forbidden all makes, all models rather than the fancy-smancy Toyota coolant?
I suppose it could be argued that the original coolant did a great job for 15 years with it being dirty and weak, but that's the only advantage I can think of.
