Originally Posted by Mad_Hatter
Originally Posted by derass
What about in cold-weather? Honda changed the oil spec of my Accord after a few years and it gets pretty cold here, so I'm switching to 0W.
Not all mfgs publish pour point/mrv data, so it's hard to do an apples to apples but my guess is you're not going to experience a demonstrable difference in cold flow characteristics between a 5/20 and 0/20 (both are using similarly light base stocks) until you go below -25/30c. Which is what, (ant)arctic cold??
we get that cold in canada alot during the winter. that being said my old 2002 RL took 5w30 PPPP and never once failed to start, even without being plugged in, the starters must be crazy strong in those. 0w20 will most likely resist oxidation better due to having better base oil composition but 5w20 will most likely have a lower noack, both will do the job good and id pick whatevers cheaper or more available.
