Need Some People to Do a Ping Test
by ZeeOSix - 05/26/20 10:22 PM
Dumb parking question.
by PhuongFU - 05/26/20 09:38 PM
spin on fuel filter
by mobilaltima - 05/26/20 09:36 PM
Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
Mesh Router System - 160MHz Backhaul?
by JHZR2 - 05/26/20 08:06 PM
Downshift before WOT?
by Avery4 - 05/26/20 08:01 PM
Getting a free 1997 Chevy 1500 extended cab
by FADEC - 05/26/20 07:22 PM
Got new tires for the trailer today
by BeerCan - 05/26/20 07:06 PM
how much cca is necessary for a truck battery?
by apollo18 - 05/26/20 06:17 PM
Electric car charge cord review
by OVERKILL - 05/26/20 04:55 PM
faulty bosch right angle drill
by benjy - 05/26/20 04:14 PM
2017 Accord Hybrid Brake Fluid Flush
by Tundragod - 05/26/20 04:12 PM
06 GMC Hybrid
by hardheaded - 05/26/20 03:57 PM
98 Camry busted oil drain plug
by JeffKeryk - 05/26/20 03:31 PM
Picked up a used Honda Push Mower today
by redhat - 05/26/20 02:43 PM
Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Any experience with MU-MIX ?
by henni - 05/26/20 01:22 PM
Bruce_S, Rwogs, MechEnDawg, jimbacot, MowerVet
71537 Registered Users
89 registered members (amblerman, alphadog, 4WD, 14Accent, 69Torino, Aero540T, 12 invisible), 2,133 guests, and 35 spiders.
Topics305,924
Posts5,282,827
Members71,537
Oil to quiet down an old '00 Legacy #5171421 07/26/19 02:44 PM
J
jayjr1105 Offline OP
J
Was talking to a friend at work who just did a bunch of top end work on his 00 legacy. He said it runs great now but has some significant valve noise. Anyone have a certain oil that helps quiet this down? Just run a 40 weight like T6?
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: Oil to quiet down an old '00 Legacy [Re: jayjr1105] #5171426 07/26/19 02:53 PM
2
2004tdigls Offline
2
any 20w50, even supertech
Re: Oil to quiet down an old '00 Legacy [Re: jayjr1105] #5171427 07/26/19 02:55 PM
B
Bjornviken Offline
B
mobil super 10w-40
Re: Oil to quiet down an old '00 Legacy [Re: jayjr1105] #5171437 07/26/19 03:08 PM
A
atikovi Offline
A
Well apparently not.
Re: Oil to quiet down an old '00 Legacy [Re: jayjr1105] #5171439 07/26/19 03:13 PM
9
928 Offline
9
If it's lifter noise, try SWEPCO 502 , if it's just worn out no weight oil will help
Re: Oil to quiet down an old '00 Legacy [Re: jayjr1105] #5171447 07/26/19 03:17 PM
SubieRubyRoo Offline
Yeah, if it makes a lot of noise it doesn't sound like he did it right. You shouldn't chase oil viscosity to try to quiet down something that needs to be fixed.
That said, EJs are typically OK to run 50 wt in warmer weather.
De omnibus dubitandum.
Re: Oil to quiet down an old '00 Legacy [Re: jayjr1105] #5171454 07/26/19 03:24 PM
J
J
Sorry I should have clarified. He had head gaskets, pumps, pulleys, belts, etc. changed. The valve noise was present before all the work.
Re: Oil to quiet down an old '00 Legacy [Re: jayjr1105] #5171458 07/26/19 03:33 PM
A
avi1777 Offline
A
Castrol definitely,magnatec or edge.
u will be surprised.
Re: Oil to quiet down an old '00 Legacy [Re: jayjr1105] #5171470 07/26/19 03:52 PM
T
talest Offline
T
You will have to try a few, see how your engine feels and sounds on each and reach a determination as to which one quiets it down the most.
Hopefully nothing happened to the engine that makes it clack and clatter like it should not, that said, I would first try some kind of 30 or 40-weight Pennzoil. Whichever one ends up working best for you is for you to find.
Quote
If the timing or valve adjustment is off, and if that is why it sounds not right (does the car stall? Accelerate well? Accelerate bad? How bad is it?) is off then crush and it's not the oil fault.
Re: Oil to quiet down an old '00 Legacy [Re: jayjr1105] #5171488 07/26/19 04:14 PM
R
Recalculating Offline
R
Pennzoil Ultra or QSUD in the flavor on the oil fill cap.
2009 Honda CR-V EX-L 63k
2007 Buick Lacrosse 63k
2008 Ford Ranger XLT V-6 4.0 SOHC 76k
Re: Oil to quiet down an old '00 Legacy [Re: jayjr1105] #5171548 07/26/19 05:52 PM
P
Padawan Offline
P
I'd go with the 15W-40 HDEO of your choice (these days I prefer Super Tech).
As SubieRubyRoo indicated, something like a 20W-50 would be fine in the summer too, and happens to be what I'm using in mine at the moment.
Re: Oil to quiet down an old '00 Legacy [Re: atikovi] #5171564 07/26/19 06:12 PM
F
FordCapriDriver Offline
F
The valvetrain clatter on my Escort is very very loud, yet ut runs like a swiss watch.
Just needs new hydraulic lifters.
1975 Ford Capri II Ghia 3000 V6 - 315k, Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - 110k, Valvoline Maxlife 10W-40
Re: Oil to quiet down an old '00 Legacy [Re: jayjr1105] #5171578 07/26/19 06:21 PM
B
burla Offline
B
Redline 5w30 is built to quiet engines, stacked with ep/aw additives and polar base oil. But, first I would try ucl, maybe it will quiet the upper end. You could always use a much thicker checper oil as well and even first, keep in back of mind of it isn't satisfactory there isn't a group 3 in 30 weight oil that will quiet more then redline 5w30. I would generally start using redline before 75k miles, if not I'd try everything else first.
Re: Oil to quiet down an old '00 Legacy [Re: jayjr1105] #5171623 07/26/19 07:23 PM
M
Miller88 Offline
M
Were the lash adjusters ever bled properly?
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Oil to quiet down an old '00 Legacy [Re: jayjr1105] #5171627 07/26/19 07:25 PM
R
Rand Offline
R
Those engines always sounded rough, similar to an old diesel tractor.
