So I am having a high pitched brake type noise coming from the right rear of my 95 LS.
I jack up the wheel and I have a tiny bit of play left to right.
I wiggle it from underneath and can't see any movement at any suspension parts.
I take off the cotter pin and locking cap and sure enough the 32mm axle nut is just loose....
It is supposed to be torqued to 213 ft lbs...
i tighten it and i no longer have a left/right rocking.
while checking further i notice that there arent any rotor set crews holding the rotor in place so it is slightly off center. The shoes are both slightly more worn at the top than the bottom. i think that as the wheel rotates the rorotr is off center and is barely rubbing on the shoes
I try a few M6 dorman honda set screws but they hold the rim like 0.5mm off the face of the hub and it rocks on them.
where can i find rotor set screws that fit? the tapered rear part of the screw hold the flat portion out too far?
file it down mb?
file it down mb?
