Nice car, I'd only consider using a couple additives, and bg moa is one of them, but not for your purposes. I like it if someone is real busy and can't change their oil or in need of a tbn boost for a particular reason, maybe a safe clean flush to add 500 miles before an oil change. The science of moly additives would suggest it would be better at killing tick then bg moa, and those are generally the only other additives I'd consider. Lubegard biotech and m0s2 are the most popular. Shaeffers says it is a moly boost, but that isn't true, it is more of an oil thickner with very low moly, not much better the lucas snot. BTW, if you want to try an oil known for killing ticks, Redline has killed more hemi ticks then anything I've seen, research it. Follow the science these particlar additives work at quieting tick, so does additives like shaefefrs or lucas, but at what cost? Those are similar to adding corn starch to a soup, they will thicken your oil like nobodies business. I'd just try shaeffers oil before their moly boost, that would actually lower moly if you add their "moly" boost to their oil. The juice isn't worth the queeze in my opinion. good luck
