Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
Grennx, coverage, Bubbabighatt, AAIRCraig, Jason454
70763 Registered Users
26 registered members (bachman, alcyon, ctechbob, CNT, 53' Stude, 3 invisible), 1,056 guests, and 15 spiders.
Topics301,733
Posts5,201,586
Members70,763
Page 1 of 3 1 2 3
Bolt Carrier Group lubrication choices #5169352 07/23/19 09:42 PM
BlueOvalFitter Offline OP
I don't like mine with excess oil, but I don't like it dry either.
I put a couple of drops of Ballistol on the bolt and rub it all over. I put a drop on the gas rings and turn it to allow the oil to move around. After the BCG is put back together I put a few drops of Ballistol on the friction parts of the BCG.
That's how I lube my BCG's.
shoot
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: Bolt Carrier Group lubrication choices [Re: BlueOvalFitter] #5169395 07/24/19 12:53 AM
K
KneeGrinder Online Content
Online Content
K
Just say NO! to Frog lube! CLP, fine, but I rarely use it. Break Free for a field action cleaner. MPro-7 LPX oil, I don't use it, but its good stuff. Slip 2000, good stuff. I use mostly oil, I put small dabs of moly grease on the bolt lugs and high wear sections of the BCG "Only when I am on the range shooting".
I use motor oil, any kind, but prefer 20W/30W for full time storage, or standby readiness for my BCG's. I'm more in the wet sloppy camp, if it does not sweat out from the upper and lower at room temp "Without Firing" in a day after applying its too dry. I oil the left inside of the upper receiver where the bolt rides also.
My pistol does not receive that much sloppy oil lube, it just gets a few drops of oil and a couple dabs of anti seize. "It gets put into places I don't want oil getting rubbed onto"! It does not need much lube anyway.
08 Tribeca 90k PUP 5w30
06 Accord 137k PP 0w20
03 Acura CL-S 90k M1 AP 5W20
02 Acura TL-S 241k ST 5W30
02 Accord EX 155k PP 0W20
02 K3500 99k M 1 ESP 5w40
00 F350 139k M 1300 15w40
Re: Bolt Carrier Group lubrication choices [Re: BlueOvalFitter] #5169440 07/24/19 05:11 AM
J
jjjxlr8 Offline
J
Some bolt carriers work better with a little grease, but you must just be talking about the AR15 rifle?
1993 Toyota MR2 Turbo
2008 Mazdaspeed3
2014 Toyota Highlander XLE
Re: Bolt Carrier Group lubrication choices [Re: BlueOvalFitter] #5169462 07/24/19 05:58 AM
AZjeff Offline
I shoot with a retired Army Small Arms Specialist who's job was to keep weapons running in the sandbox. He put a drop of oil on the gas rings only there and the same here. Situation and environment determines best practice. What you do sounds good for a range-home gun. Kneegrinder's lube works for him in Idaho but wouldn't do so well in the desert.
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Bolt Carrier Group lubrication choices [Re: BlueOvalFitter] #5169469 07/24/19 06:09 AM
L
Linctex Offline
L
Yes, sir - he is
here's the giveaway:
Re: Bolt Carrier Group lubrication choices [Re: BlueOvalFitter] #5169485 07/24/19 06:43 AM
T
Trav Offline
T
LSA is still a good choice for these weapons.
Re: Bolt Carrier Group lubrication choices [Re: BlueOvalFitter] #5169491 07/24/19 07:00 AM
W
WyrTwister Offline
W
I have assembled an AR from new parts . Would not cycle properly unless run WET . After a break in period ,, it would run fine with a moderate amount of lube .
When I change the oil / filter on a vehicle , I save the " empty " oil containers & let then drain for a period of time into one of my oil squirt cans .
I have also been given old odd ball containers of oil & ATF . They make good gun oil too .
Wyr
God bless
Re: Bolt Carrier Group lubrication choices [Re: BlueOvalFitter] #5169528 07/24/19 07:44 AM
B
buck91 Offline
B
I generally use breakfree clp on all my firearms with fluid film wipe downs on blueing... though I am starting to lean towards BF’s LP instead.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Bolt Carrier Group lubrication choices [Re: BlueOvalFitter] #5169544 07/24/19 08:07 AM
B
bubbatime Offline
B
In my experience, Balistol burns off so fast your head will spin. Its not a good AR15 lube, in my opinion.
Here are the bubbatime tested and approved AR15 lubes.
FP10
Breakfree LP (not CLP)
Weaponshield
Slip 2000 EWL30
Slip 2000 EWL
ALG very thin grease
Mil-Comm TW25b grease
Caviat edit: Ive bought most of these at much cheaper prices than they are available today. I wont spend $15 or $25 on a bottle of gun lube, when the $8 bottle of Breakfree works just as good.
And most people don't know how to lube an AR bolt carrier group. You can leave almost the entire thing dry, as most of it doesn't touch anything. Put a heavy lube application on the 4 rails, on the gas rings, on the cam pin, the forward and rear facing lugs of the bolt, a smidgen on the firing pin, and one drop of oil worked into the ejector.
[Linked Image]
2019 Honda CRV 1.5T dealer bulk
2017 Chrysler Pacifica SuperTech synthetic 5W20
2013 Yamaha XT250 Valvoline motorcycle 10W40
2006 GMC Sierra SuperTech high mileage 5W30
Re: Bolt Carrier Group lubrication choices [Re: BlueOvalFitter] #5169619 07/24/19 09:48 AM
W
Ws6 Offline
W
shoot
Slip 2000 EWL, dripping.
2019 CX5 Grand Touring Reserve
Re: Bolt Carrier Group lubrication choices [Re: AZjeff] #5169623 07/24/19 09:49 AM
W
Ws6 Offline
W
Best practice in the desert with a bunch of moon dust is sloppy wet, clean often, keep your ejection port door closed and a mag in the gun of course.
Re: Bolt Carrier Group lubrication choices [Re: BlueOvalFitter] #5169680 07/24/19 10:54 AM
M
MGF1964 Offline
M
Got no experience in the desert, so won't address that.
For a range gun in the Midwest, here's what I do:
1) Single drop of a decent oil in the recommended places, especially the rings.
2) Drop or two of oil on a fingertip for the bolt body and BCG body. Just a wee bit of corrosion protection is all I'm looking for.
3) For the rails, I pick something that's slick, slightly thick (for adhesion) and without easy burnoff. Most stuff works in a moderate amount, IMO. Among oils (liquids), I've used BreakFree, G96 synthetic, FP10, Super Lube. Among greases, I've used TW25B and Lubriplate SFL-0. Have also tried LSA (do we call that an oil or a grease?). All worked just fine.
Re: Bolt Carrier Group lubrication choices [Re: BlueOvalFitter] #5169700 07/24/19 11:13 AM
Astro14 Offline
I like Ballistol for many uses - but mostly, I use it to wipe down wood/metal guns, and my axes and other outdoor tools. It won't hurt the wood, or leather sheaths, while still protecting the metal.
I saw the diagram that Bubbatime posted many years ago. That's how I lube a BCG - there are lots of points, many of them generous. You can tell where the lube is needed by looking at an older BCG - the finish wears off quickly on the rails, on the inside of the BCG where the cam pin rides, and on the cam pin itself. It wears off slightly less quickly on the lugs, bolt body ring, and the extractor pin. Those areas clearly need generous lube.
While I think that guns in general aren't particular about lube, I think that AR-15s are the most picky of all the guns I've owned. Ballistol is mostly mineral oil, and I would choose something better at lubrication than Ballistol for an AR-15 BCG. I've heard great things about Weapon Shield, and my son in law, who shoots a LOT in competition, raves about it. An excellent endorsement.
I've had good results with the AMSOIL gun lube in recent use. Lots of shooting in a dusty environment, gun in the dirt or in contact with the dirt, no cleaning all day, and the gun was field-stripped at the beginning of one stage, lying on a dusty bit of cardboard. It was pretty dirty, with lots of dust/dirt inside the receiver, along with the usual powder residue/junk that AR-15s accumulate.
No failures, no signs of problems with my AR in that competition, so, I can recommend the AMSOIL. At $7 for a 4 oz. bottle, it's a tremendous value when compared with the other gun lubes on the market.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Bolt Carrier Group lubrication choices [Re: BlueOvalFitter] #5169701 07/24/19 11:14 AM
B
buck91 Offline
B
delete
2011 F150 4x4 5.0L
Re: Bolt Carrier Group lubrication choices [Re: Ws6] #5169746 07/24/19 12:03 PM
AZjeff Offline
Next time I see him I'll tell him he was doing it all wrong.
Page 1 of 3 1 2 3
