WiFi Network Monitoring Tool
by ZeeOSix - 06/06/20 09:47 PM
a sad day for our family
by miden851 - 06/06/20 09:26 PM
pressure starts up first try after not used for 6 months
by motor_oil_madman - 06/06/20 08:50 PM
Any Recommendations For LED Shop Lighting
by walterjay - 06/06/20 08:36 PM
Which brake pads for towing?
by pburchett - 06/06/20 08:27 PM
supertech 0w16 $11/ 5 qt
by eljefino - 06/06/20 07:55 PM
Pennzoil 5W-20 HM Ecobox? $2.27????
by Jackson_Slugger - 06/06/20 07:50 PM
Fluid for Jeep electric-boosted spower steering?
by Jeffrey Behr - 06/06/20 06:33 PM
Bottom grill hitting radiator fan
by dan765 - 06/06/20 06:26 PM
Unknown mystery oil
by Zgrant231 - 06/06/20 06:23 PM
Paint Protection Film (PPF)
by HDoilDude - 06/06/20 05:40 PM
Old RedMax EBZ8001
by BISCUT - 06/06/20 04:57 PM
ATF as general purpose oil?
by buck91 - 06/06/20 04:29 PM
Silicone vs fumed silica?
by buck91 - 06/06/20 04:24 PM
e-bike conversion kit
by OilUzer - 06/06/20 03:49 PM
Computer - Hypervisor - Increase I/O Performance
by brueggma1 - 06/06/20 03:30 PM
Inside of new windshield fogs up
by mclasser - 06/06/20 02:51 PM
Jeancando, SkulltulaHouse, geekofband007, jproposki, 1mzsludge
71625 Registered Users
72 registered members (bbhero, 4WD, AdRock, ammolab, AZjeff, b1amgm47, 12 invisible), 1,747 guests, and 27 spiders.
Topics306,318
Posts5,290,048
Members71,625
SuperTech Full Syn 20 weight 7461 miles 16 Silverado 4.3 V6 #5169313 07/23/19 09:51 PM
A
AtlasFBG2 Offline OP
A
Here is my used oil analysis on my 2016 Chevy Silverado 4x4 4.3 Ecotech3 V6 with 7461 miles on the oil.
Oil was a mix of 3 quarts 0w20 and 3 quarts of 5w20 Walmart SuperTech Full Synthetic. No make up oil was added. Oil life monitor was at 1% remaining.
Oil filter was SuperTech st10575. Air filter was the original factory and was changed with oil.
Factory recommends this engine to use 5w30 oil. I wanted to try a 20 weight oil to get the truck in v4 mode more often for fuel savings.
Looks good except cooper is a little higher than average for this engine.
Re: SuperTech Full Syn 20 weight 7461 miles 16 Silverado 4.3 V6 [Re: AtlasFBG2] #5169319 07/23/19 10:01 PM
B
benjy Offline
B
save a little fuel but add some xtra wear. 5-30 might make a 1/4 mpg less as lighter oils are for the epa standards manufacturers want to meet!
Re: SuperTech Full Syn 20 weight 7461 miles 16 Silverado 4.3 V6 [Re: benjy] #5169359 07/23/19 11:03 PM
I
IndyFan Offline
I
And what evidence do you have that there was more wear than with 5w30?
18 Jeep JLUR Wrangler 3.6 31k
15 Ford Transit 129k, Reman 3.5 @85k
17 Jeep Renegade 2.4 29k
08 Jeep Wrangler 3.8 141k
04 Jeep Grand Cherokee 4.7 111k
99 Mercedes E430 Sport 90k
Re: SuperTech Full Syn 20 weight 7461 miles 16 Silverado 4.3 V6 [Re: AtlasFBG2] #5169441 07/24/19 06:14 AM
dnewton3 Offline
Global Moderator
Global Moderator
The 4.3L engine is based on the old GM 5.7L with two cylinders lopped off. That old first gen engine was not known for great wear rates, so it's no surprise that this one example is wearing about the same. The copper is just one reading, as are they all. Let's not read too much into this year. The avg Fe is about 4ppm/1k miles; that's actually a tad lower than the avg for this engine design. I'm not saying the old design won't last a long time; they will run a long while if you care for them. But the wear rates are higher than what we'd see from other brands/designs. And if this engine has AFM cylinder deactivation, that also adds wear from the cam system.
Looks decent. Keep running it.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: SuperTech Full Syn 20 weight 7461 miles 16 Silverado 4.3 V6 [Re: AtlasFBG2] #5169449 07/24/19 06:36 AM
A
A_Harman Offline
A
The Ecotec 4.3 is based on the LT series of engines. Direct injection, replicated porting, deep-skirt cross-bolted engine block, aluminum block and heads, with deactivating roller followers on two cylinders.
I think the OP should run 5w30 as specified by GM. The smaller displacement engine in a standard-size truck works harder.
2008 Dodge Ram 3500 diesel/G56
1985 Z51 Corvette track car 355/6-speed
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel/NV4500+GV
1972 GMC 1500 shortbed project truck 307/SM465
Re: SuperTech Full Syn 20 weight 7461 miles 16 Silverado 4.3 V6 [Re: AtlasFBG2] #5169464 07/24/19 07:01 AM
diyjake Offline
I would never use thinner oil than recommended.
Re: SuperTech Full Syn 20 weight 7461 miles 16 Silverado 4.3 V6 [Re: A_Harman] #5169513 07/24/19 08:26 AM
dnewton3 Offline
Global Moderator
Global Moderator
Well I may be way off base then. I thought the 4.3L was still based on the old architecture. They may have added wizardly and gizmos, but it's not the same old design? Not same bore center and deck height? Not the same journal sizing? I stand corrected quite likely, then.
The cyl deactivation typically adds a couple PPM per 1k miles. I've seen that repeatedly in the Vortec engines.
Re: SuperTech Full Syn 20 weight 7461 miles 16 Silverado 4.3 V6 [Re: AtlasFBG2] #5169866 07/24/19 04:05 PM
M
Macsignals Offline
M
Was this truck optioned with an oil cooler? The 4.3 doesn't come standard with one but it can be added as a factory option. That's some people's reasoning for GM specifying 5W30 in the 4.3 versus the 5/0W20 they spec in the 5.3L and 6.2L V8s.
And yes aside from bore spacing carrying over from the small block and LS series, these new 4.3s are a clean sheet based on the LT series. Displacement wise it is basically a 3/4 LS1, but in the LT series so it has the direct injection and everything else.
-Ian A.
Mine:
2016 GMC Sierra 1500, L83 5.3L V8. Castrol Magnatec 0w20, Bosch 3502 oil filter. Daily driver.
1992 Dodge Dakota, 3.9L V6. Delvac 10W30, Napa Silver filter. Out of service for restore.
Re: SuperTech Full Syn 20 weight 7461 miles 16 Silverado 4.3 V6 [Re: dnewton3] #5169888 07/24/19 04:38 PM
A
A
From what i read the 4.3 was redesigned in 2014. Here is some info on it and the 5.3 http://gmauthority.com/blog/gm/gm-engines/lv3/
Re: SuperTech Full Syn 20 weight 7461 miles 16 Silverado 4.3 V6 [Re: Macsignals] #5169909 07/24/19 04:53 PM
A
A
The truck has the factory towing package. I think it has a oil cooler. There are lines on both sides of the radiator. I would have to crawl under the tuck and trace the lines to be certain on that.
There is another ecotech3 4.3 v6 uao i found that used the factory recommend 5w30 oil. Comparing the reports mine is lower with the exception of tin. The other report has the copper at 103 and iron at 40. Although the other report only had like 12,000 miles on the engine.
Here is a link to the other 4.3 report https://www.bobistheoilguy.com/forums/ubbthreads.php/ubb/showflat/Number/4589307/Searchpage/1/Main/280062/Words/%2Bsilverado+%2B4.3/Search/true/16-silverado-4-3-ecotec-6-802-miles#Post4589307
Re: SuperTech Full Syn 20 weight 7461 miles 16 Silverado 4.3 V6 [Re: AtlasFBG2] #5169960 07/24/19 06:03 PM
dave1251 Online Happy
Online Happy
This is a stout engine but I recommend using the recommended grade and honestly if you're not getting the fuel economy desired from this power train I full size pickup isn't for you.
don't use.
Re: SuperTech Full Syn 20 weight 7461 miles 16 Silverado 4.3 V6 [Re: AtlasFBG2] #5170548 07/25/19 12:21 PM
diyjake Offline
Looks like ST held up pretty good especially for 7,400 miles
Re: SuperTech Full Syn 20 weight 7461 miles 16 Silverado 4.3 V6 [Re: AtlasFBG2] #5170636 07/25/19 02:09 PM
J
jayjr1105 Offline
J
In agreement with others... Run the recommended weight. Sometimes we're tempted to go a little heavier but I see no advantage to a thinner than recommended oil.
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: SuperTech Full Syn 20 weight 7461 miles 16 Silverado 4.3 V6 [Re: AtlasFBG2] #5259154 11/05/19 02:17 PM
A
A
Ran a test on the second run of using 20 weight oil. This is the same mix of Supertech full synthetic three quarts of 0w20 and three quarts of 5w20.
[Linked Image]
Re: SuperTech Full Syn 20 weight 7461 miles 16 Silverado 4.3 V6 [Re: AtlasFBG2] #5260177 11/06/19 07:20 PM
A
ad244 Offline
A
I'd be curious to see how the Synthetic would compare using the same viscosities. Probably very little would change.
Thanks for posting this up OP
