Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
Grennx, coverage, Bubbabighatt, AAIRCraig, Jason454
70763 Registered Users
30 registered members (bachman, alcyon, ctechbob, CNT, 53' Stude, 5 invisible), 1,024 guests, and 16 spiders.
Topics301,733
Posts5,201,589
Members70,763
Focus SVT backyard head rebuild.....assembly lube vs oil? #5169267 07/23/19 07:51 PM
dx92beater Offline OP
Hi,
History:
Due to this head being nearly impossible to find combined with incompetent machine shops in my area....
I am in the process of rebuilding the head for the subject vehicle. I lapped the used valves I put in (previous valves bent at idle from defective OEM tensioner) and then gasoline tested for leaks and there were none. Yes, I removed the lapping compound.
I cleaned up everything, installed new valve stem seals, old springs from another head, old retainers from another head, used cams from another head, correctly oriented old cam caps, and keepers. I lubed those parts with a coating of Rotella T6 5w-40.
I am about to do some lash adjustments with guess what? Used buckets.
I have lots of different lubricants laying around but no engine assembly lube. With all of the variables involved, the backyard head job and a high risk of another timing incident on this interference engine would you just lube everything up with RT6 and see what happens or would you go with assembly lube? If so, which one?
Thanks.
Galant VR4, Talon TSI AWD, Forester XT, Caravan AWD, Focus, GMC Truck
Re: Focus SVT backyard head rebuild.....assembly lube vs oil? [Re: dx92beater] #5169282 07/23/19 08:06 PM
Chris142 Offline
Oil will be fine if it does not sit a long time before started.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Focus SVT backyard head rebuild.....assembly lube vs oil? [Re: Chris142] #5169289 07/23/19 08:13 PM
1
14Accent Offline
1
I would agree.
Assembly lube is very "sticky". It clings to the parts, assuming an engine build will take a while.
5w40 will be a fine lube. When you start the engine, disable the fuel and crank the engine in maybe 5 15 second bursts. This should build and hold PLENTY of pressure and lube all the critical parts before startup.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: Focus SVT backyard head rebuild.....assembly lube vs oil? [Re: dx92beater] #5169416 07/24/19 04:13 AM
Silverado12 Offline
FWIW I've always used STP and you can get it just about everywhere incl. Wal-Mart.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Focus SVT backyard head rebuild.....assembly lube vs oil? [Re: dx92beater] #5171584 07/26/19 05:26 PM
Thanks all.
