I've been changing oil on my cars for 50 years or so, so this ain't my first rodeo. But I had a new oil filter oil experience (sad, isn't it, when new experiences are oil filter-related).
Changed the oil on my 2015 Honda CRV about 2,000 miles ago and used a Wix filter for the first time. I used the specified 57356XP and tightened it the usual 3/4-1 turn after gasket contact. Checked for leaks and all was well. Checked oil level periodically since with no noticeable change in level and an absolutely clean garage floor. Came home today when that car was out and saw an oil spot. Checked when it was back and the filter was leaking at the gasket.
Replaced the filter with my usual OEM Honda and noted the Wix was on tight and had no visible defects.
So, this is a new and disturbing development that could have stranded us if the leak got lots worse in a hurry. Any theories? Has this happened to anyone else? Wix seems to have a good rep here, but I've turned into a skeptic.
Thanks.
Thanks.
