Intel or AMD Processor
by ZeeOSix - 02/28/20 04:02 AM
Denso Reman Starter Noise
by The Critic - 02/28/20 02:59 AM
Gratitude
by rrretiree7 - 02/27/20 11:56 PM
Maxlife for 35yo Ford C6
by Cubey - 02/27/20 11:35 PM
New 2-post lift on order
by clinebarger - 02/27/20 11:07 PM
New F-150 2.7 EB recommendations?
by mattri - 02/27/20 09:37 PM
Honey I bought a set of wheels
by P10crew - 02/27/20 09:29 PM
PQIA Pennzoil Hybrid 0W-16
by kstanf150 - 02/27/20 08:32 PM
100,000 ducks sent to Pakistan.
by Vern_in_IL - 02/27/20 08:07 PM
06 Camry Coolant??
by Jcountry - 02/27/20 07:54 PM
PQIA Kirkland 5W-30 synthetic
by kstanf150 - 02/27/20 07:43 PM
401 K took a beating!
by P10crew - 02/27/20 07:30 PM
Coolant Level
by rrretiree7 - 02/27/20 07:21 PM
Techron BOGO at O'Reilly
by TheLawnRanger - 02/27/20 06:26 PM
"Follow Thread" not working anymore?
by atikovi - 02/27/20 06:25 PM
What happened at Hyundai dealers
by WhyMe - 02/27/20 06:23 PM
Using ramps for oil change?
by superfat_dad - 02/27/20 06:03 PM
hogryder007, Sabbag77, RpR, jameswilliam, Agraz400
70819 Registered Users
81 registered members (4WD, advocate, 2015_PSD, alarmguy, atikovi, AZjeff, 8 invisible), 1,520 guests, and 14 spiders.
Topics302,028
Posts5,207,578
Members70,819
Page 1 of 4 1 2 3 4
Sorry, but I need help again #5168552 07/22/19 10:41 PM
NavyVet88 Offline OP
2002 Ford Ranger Edge 3.0 67k
Hey guys,
I know I’m beating a dead horse about my truck, but I am about to lose my mind with this. I did a compression test this past Sunday and cylinders 1,2,3,4,5,6 were 165,164,160,160,165,170 respectively. My compression seemed good.
I thought I had fixed the rough idle by replacing the coil pack, but no. Also, tonight on my way home from work at 60-65mph on the interstate I feel what feels like a misfire. It’s not bad enough to be scary, but it’s noticeable. I pulled off my exit to a stop sign and magically there’s no rough idle. Engine was purring. After pulling off, I get to around 50 mph and I feel the “misfire” again. The next 18 miles until I arrived home would produce the “misfire” between 40-50 mph. The symptoms don’t exactly match what I have researched as possible culprits.
Bad/faulty fuel injector(s)- wouldn’t this produce a more constant misfire and rough idle? Fuel economy seems decent for the age of the truck. First full tank of highway miles produced 335ish miles on a 16.5 gallon tank.
O2 sensor(s)- no rotten egg smell that I have read about associated with this and again fuel economy doesn’t seem affected.
Engine has no EGR valve.
No check engine light or codes....
Replaced parts- coil pack, plugs, plug wires, serpentine belt/tensioner/idler pulley(needed changing), cam sensor and synchronizer, and fuel filter.
I’m out of ideas guys.
2013 Honda Civic LX 1.8L 178k M1 HM 0w20 with Fram XG7317
2002 Ford Ranger Edge 3.0L 67k Castrol Edge 5w30 with Fram XG3600
Maintenance Technician by trade, working class for life.
Re: Sorry, but I need help again [Re: NavyVet88] #5168556 07/22/19 10:46 PM
K
KrisZ Offline
K
Did you check for vacuum leaks?
2015 Grand Caravan 3.6L - 35k miles.
2006 Mazda 3 2.0L - 186k miles
Re: Sorry, but I need help again [Re: NavyVet88] #5168560 07/22/19 10:49 PM
Marco620 Offline
Bad gas?
15' Civic 1.8 i-vtec 311,000 mi M1 0w30 & LG Biotech, BP CVT Fluid,GUMOUT W/ PEA
Doberman Whisperer!
E pluribus unum.
Re: Sorry, but I need help again [Re: KrisZ] #5168561 07/22/19 10:50 PM
Yes and I did not find any. Doesn’t mean I missed a leak, but I did not find one after multiple checks with carb cleaner.
Re: Sorry, but I need help again [Re: Marco620] #5168565 07/22/19 10:54 PM
Originally Posted by Marco620
Bad gas?
Considered this. I have filled up multiple times from local “prominent” gas stations and have the exact same issues across 87,89 and 93 octane.
Re: Sorry, but I need help again [Re: NavyVet88] #5168566 07/22/19 10:57 PM
A
A_Spruce Offline
A
Is there a relation of misfire to speed, rpm, or engine load?
'03 Suburban
Re: Sorry, but I need help again [Re: A_Spruce] #5168569 07/22/19 11:04 PM
Rpms do not jump/bounce or change at all with the “misfire” or the rough idle. Under load going up a hill for example, there is no misfire feeling. Seems most noticeable on level ground at cruising speeds of anywhere from 40-65mph. The rough idle is intermittent between stops seeing as I don’t feel it every time I come to a stop.
Re: Sorry, but I need help again [Re: NavyVet88] #5168577 07/22/19 11:12 PM
Dylan1303 Offline
Hows your ltft? That might tell a story
12 cruze rs 1.4t 6spd pp 5w30 tuned on 22psi
19 cruze auto 1.4t amsoil oe 5w20 tuned on 24psi
Re: Sorry, but I need help again [Re: NavyVet88] #5168579 07/22/19 11:13 PM
I feel like I am chasing a ghost seeing as I can’t find anything in my troubleshooting, yet have an issue. I am a maintenance technician by trade and my livelihood is based off of precise troubleshooting and fixes on equipment that is running 24/7.
Re: Sorry, but I need help again [Re: Dylan1303] #5168580 07/22/19 11:14 PM
Ltft?
Edit: long term fuel trim. Gotta love google. I have no clue honestly. How would I go about checking this?
Re: Sorry, but I need help again [Re: NavyVet88] #5168586 07/22/19 11:34 PM
Before I make myself out to sound like an idiot, I’m a maintenance tech on industrial electronics and mechanical. Saying that my livelihood is based on precision yet I’m being bested by a rough idle on a truck lol I’m only so versed in automotive stuff.
Re: Sorry, but I need help again [Re: NavyVet88] #5168590 07/22/19 11:41 PM
A
A_Spruce Offline
A
Something is telling me a dirty MAF sensor, but I have nothing to back that theory up. Did you check the intake snorkel for air leaks between the MAF and intake manifold?
'03 Suburban
Re: Sorry, but I need help again [Re: NavyVet88] #5168596 07/22/19 11:58 PM
Snagglefoot Online Content
Online Content
I would recommend having a close look at your coil pack and inspect it carefully, if it has any cracks, especially in the underside of it, replace it. Motorcraft only.
If you want the job done right......do it yourself.
Re: Sorry, but I need help again [Re: NavyVet88] #5168600 07/23/19 12:23 AM
Dylan1303 Offline
With a scan gauge or plug in obd thing. +10 to -10 is acceptable. If your ltft are say -30 that means its pulling 30% fuel over stock map. So that would say leaky injector you know stuff like that. If it was like +30 you would have a large vacuum leak or something since its adding %30 fuel.
Ltft?
Re: Sorry, but I need help again [Re: NavyVet88] #5168603 07/23/19 01:11 AM
O
oldhp Offline
O
Throttle blade clean and IAC valve clean??? MAF sensor clean???
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Page 1 of 4 1 2 3 4
