Intel or AMD Processor
by ZeeOSix - 02/28/20 04:02 AM
Denso Reman Starter Noise
by The Critic - 02/28/20 02:59 AM
Gratitude
by rrretiree7 - 02/27/20 11:56 PM
Maxlife for 35yo Ford C6
by Cubey - 02/27/20 11:35 PM
New 2-post lift on order
by clinebarger - 02/27/20 11:07 PM
New F-150 2.7 EB recommendations?
by mattri - 02/27/20 09:37 PM
Honey I bought a set of wheels
by P10crew - 02/27/20 09:29 PM
PQIA Pennzoil Hybrid 0W-16
by kstanf150 - 02/27/20 08:32 PM
100,000 ducks sent to Pakistan.
by Vern_in_IL - 02/27/20 08:07 PM
06 Camry Coolant??
by Jcountry - 02/27/20 07:54 PM
PQIA Kirkland 5W-30 synthetic
by kstanf150 - 02/27/20 07:43 PM
401 K took a beating!
by P10crew - 02/27/20 07:30 PM
Coolant Level
by rrretiree7 - 02/27/20 07:21 PM
Techron BOGO at O'Reilly
by TheLawnRanger - 02/27/20 06:26 PM
"Follow Thread" not working anymore?
by atikovi - 02/27/20 06:25 PM
What happened at Hyundai dealers
by WhyMe - 02/27/20 06:23 PM
Using ramps for oil change?
by superfat_dad - 02/27/20 06:03 PM
hogryder007, Sabbag77, RpR, jameswilliam, Agraz400
70819 Registered Users
73 registered members (4WD, alarmguy, avi1777, AurionX2, Astro_Guy, 2015_PSD, 8 invisible), 1,254 guests, and 20 spiders.
Topics302,028
Posts5,207,538
Members70,819
Water spot remover #5168218 07/22/19 02:40 PM
R
Redright9 Offline OP
R
Hello,
What is a good water spot remover. I am looking at the chemical guys spot remover, but curious who has had good luck with what... One of my cars has some spots that have been on there a while.. Any suggestions?
Re: Water spot remover [Re: Redright9] #5168266 07/22/19 03:40 PM
E
Ed_Flecko Online Content
Online Content
E
I'm going to make a guess that those water spots *may* not come off without polishing, in some form or fashion, depending on the mineral content of the water that made the spots, etc.
Ed
K-9s teach the suspect that if you run...you'll only be arrested tired.
Support YOUR local law enforcement K-9 Unit!
https://www.ssdk9.com/
Re: Water spot remover [Re: Redright9] #5168268 07/22/19 03:42 PM
R
R
I was a little worried about that.
Re: Water spot remover [Re: Redright9] #5168283 07/22/19 03:52 PM
David2431 Offline
This works great on fiberglass, even black colors. Don't know why it wouldn't work on a cool car in the shade. [Linked Image]
Re: Water spot remover [Re: Redright9] #5168392 07/22/19 06:30 PM
R
Reddy45 Offline
R
Try plain white vinegar on a rag first. If that doesn't do it, then the spot is etched into the paint and may require compound/polish.
Re: Water spot remover [Re: Redright9] #5168408 07/22/19 06:59 PM
P
parshisa Online Content
Online Content
P
carpro spotless for me -makes wonders removing those pesky waterspots
'17 Honda Civic 1.5T/ 6MT
'16 Honda Pilot 3.5NA/6AT
Re: Water spot remover [Re: Redright9] #5168448 07/22/19 07:57 PM
J
joekingcorvette Online Content
Online Content
J
I use 1/2 white vinegar and 1/2 water with a few drops of dawn soap to take water spots off my black 4 stroke engines and my boat. It works very well. For extremely bad water spots use rubbing compound with a power buffer. Sometimes water spots cannot be removed if etched into the paint.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: Water spot remover [Re: Redright9] #5168542 07/22/19 10:19 PM
K
KneeGrinder Offline
K
If they won't come off with a rag and strait cheap white vinegar, next try that same cheap white vinegar and a clay bar. If that does not work, I have had to sand really bad "Mineral" deposits with 1000/1200 grit sand paper and white vinegar, then polish with machine polisher, compound, and glaze. I would strongly suggest you not use a machine polisher unless you have a bit of experience, you could ruin the paint very quickly!
If you have someone else remove water spots with just a machine polisher, and not use vinegar and sandpaper to remove them, the spot will come back like a ghost! It will be gone when finished with the polishing, but will reappear soon after and remain permanently.
08 Tribeca 90k PUP 5w30
06 Accord 137k PP 0w20
03 Acura CL-S 90k M1 AP 5W20
02 Acura TL-S 241k ST 5W30
02 Accord EX 155k PP 0W20
02 K3500 99k M 1 ESP 5w40
00 F350 139k M 1300 15w40
Re: Water spot remover [Re: Redright9] #5168647 07/23/19 05:21 AM
V
Vikas Offline
V
Say what? Use 1000 grit sand paper but be afraid of machine polisher????
Re: Water spot remover [Re: Redright9] #5168743 07/23/19 07:53 AM
W
WylieCoyote Offline
W
Any semi-functioning human can use a random-orbital. You'd pretty much have to be trying to screw up paint with one. Rotaries are the ones you need to be careful of. They swirl and burn paint if you don't know what you're doing. For water spots, or any other blemish, start with a light approach and work your way up to machine polishing if chemical treatments don't work. There's no need to remove clear coat if you don't need to. I'd start with vinegar, and possibly a clay bar.
2015 GMC Canyon 3.6
2018 Mustang Ecoboost Convertible
Re: Water spot remover [Re: Redright9] #5168747 07/23/19 07:58 AM
Duffyjr Offline
#0000 steel wool and Sprayway or a good window cleaner for the lubrication and only go in one direction. This advice was given to me by a window shop here in town, while it didn't remove all of it, it made it much better.
89 GMC Sierra Advanced 5w30/51036 Wix
08 Lucerne CX Advanced 5w30/1040 Gold
18 Toro Super Recycler T5 10w30
