Oil Prices in Europe
by BBDartCA - 02/23/20 08:08 AM
Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles on oil?
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Chaucha, UofA, Jeffrey78, Markovchain, o_s
70787 Registered Users
88 registered members (4WD, 2015_PSD, 53' Stude, 74Widebody, 55hambone, 8 invisible), 1,893 guests, and 16 spiders.
Topics301,820
Posts5,203,301
Members70,787
Do wheel bearings go bad from static loads? #5167759 07/22/19 02:06 AM
Deontologist Offline OP
I know someone who purchased a car that had been parked for 8 months. The wheel bearing was shot off the bat. The seller explained that it must have gone bad from sitting for 8 months. Is this plausible? I had no idea static loads could damage wheel bearings. And it's not like the car was parked in a pit of mud with water up to the fenders.
Re: Do wheel bearings go bad from static loads? [Re: Deontologist] #5167764 07/22/19 03:21 AM
L
Lubener Offline
L
Was it new??? If it is used, maybe it was already in bad shape when they bought it. To answer, I can't see how just being parked could do that.
The "thinking" man's friend.
Re: Do wheel bearings go bad from static loads? [Re: Deontologist] #5167787 07/22/19 05:10 AM
T
Tman220 Offline
T
NO!! Just a story from the seller to skirt responsibility, nothing more.
2012 Regal GS Turbo PP 5w30 90k
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30 165k
2005 GMC Sierra 1500 5.3 166k
2004 Civic LX M5 186k
2007 Camry 2.4 245k
2016 Victory Vegas
Re: Do wheel bearings go bad from static loads? [Re: Deontologist] #5167788 07/22/19 05:13 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
Nope, can't happen.
Re: Do wheel bearings go bad from static loads? [Re: Deontologist] #5167807 07/22/19 05:43 AM
J
jacobsond Offline
J
Bearings can be damaged from static loads.Its not really noticeable unless your are in a precision application.Wheel bearings in a car no way. They were likely on their way out already. They likely had a little water in them or just condensation. 8 months of sitting there rusting away now bad. Did the seller know the bearings were going bad not likely.
Re: Do wheel bearings go bad from static loads? [Re: Deontologist] #5167829 07/22/19 06:18 AM
Chris142 Offline
As already said no. They can be damaged in shipping if the car is not tied down good and moves a tiny amount, allowing the grease to be worn away from the rollers.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Do wheel bearings go bad from static loads? [Re: Deontologist] #5167847 07/22/19 06:57 AM
P
pcoxe Offline
P
It's possible with large electric motors. Wheel bearings . . . ?
Bearing Damage Possible
Even when a motor is not rotating, it may still be subject to vibration. Proximity to rail lines, busy roads, and/or productions floors will all contribute to the ambient vibration. Even low-magnitude vibration, over time, can cause bearing damage such as false brinelling. This occurs when the machine bearings are stationary but subjected to repeated vibration. Such damage may not be visible to the naked eye until the machine has been placed into operation, when it quickly worsens. I know of one mill where all stored motors are placed on old conveyor belting, to dampen the ambient vibration from nearby machinery.
Motors placed into long term storage should have the shaft rotated at regular intervals both to prevent false brinelling and to redistribute lubricant on the metal surfaces to prevent corrosion. The recommended time interval is monthly depending on the size of the machine. Larger 2 pole machines require more frequent attention than smaller (NEMA-frame) machines. In the case of heavy machines with heavy rotors and long frames, regular rotation of the shaft is critical to prevent the shaft distortion cause by rotor sag. This is a consideration for machines rates approx 1500 hp (1000 KW) and larger. Such machines may need to be rotated weekly. As an extreme example, very large generators a kept rotating slowly at all times to prevent sag. While uncommon, for critical, very large machines, the rotor can be removed and suspended vertically to prevent sagging.
Re: Do wheel bearings go bad from static loads? [Re: Deontologist] #5167850 07/22/19 06:58 AM
M
Mad_Hatter Offline
M
On modern cars the wheel bearings are sealed at the factory and lubed for life.
So Fake News!😉
Re: Do wheel bearings go bad from static loads? [Re: Deontologist] #5167851 07/22/19 06:58 AM
Hootbro Offline
Buying used can be a pig in a poke. There is a sliding scale of how people will lie. The higher the cost and liability, the bigger they lie. That is why "as is" is a thing and vehicles should have a independent inspection for such things.
2020 Jeep Gladiator Rubicon 3.6L (Dealer Bulk 0W-20)
2017 Jeep Renegade Latitude 2.4L (Idemitsu 0W-20)
2013 Volkswagen Jetta 2.5L (Havoline HM 5W-30)
Re: Do wheel bearings go bad from static loads? [Re: Deontologist] #5167860 07/22/19 07:16 AM
W
WyrTwister Offline
W
I am an old duffer & more familiar with wheel bearings from the 70's . I think more modern cars often have sealed bearings .
Unless salt / water gets into the bearing , probably not . Would not be on my list of things to check when shopping for a car , unless I saw other evidence of salt / rust .
We own my lat Mom & Dad's 1991 Caprice with less than 50,000 miles on it . Never considered bearings , although , if we started driving it again , might need to pack the front wheel bearings ? And check all the fluids , including the diff .
To the OP , mow many miles on the odometer of the vehicle in question ?
Wyr
God bless
Re: Do wheel bearings go bad from static loads? [Re: WyrTwister] #5167862 07/22/19 07:24 AM
M
Mad_Hatter Offline
M
My first car I had to occasionally repack the bearings. I'm just spit balling here but I'd say sealed bearings have been in place for the last 30yrs??? So unless it's a classic vehicle, I can't see it happening.
Re: Do wheel bearings go bad from static loads? [Re: Deontologist] #5167872 07/22/19 07:37 AM
B
Blkstanger Offline
B
Sounds like a flood car.
99 Jeep WJ 4.7 200,000mi. Maxlife 10w30, Fram Ultra.
15 Ford Escape S 2.5 Castrol Edge EP 5w30 Fram Ultra.
Re: Do wheel bearings go bad from static loads? [Re: Deontologist] #5167873 07/22/19 07:40 AM
SubieRubyRoo Offline
Probably not on the bearing... meaning it was already bad and the seller knew it.
One story close to home that could not have been predicted: I had a 2001 Forester that I owned since 2011 and put over 80k miles on it with no known problems other than the center exhaust bolts had rusted through, easy fix. I sold it to my brother back in April. He detailed the car and flipped it and sold it to a guy that worked for him. Guy called him Saturday and said "I was driving the car, hit a pothole, and the car literally changed lanes! I took it to a shop nearby and he said the rear subframe was so rusty that it snapped when I hit the pothole." So my brother did the stand-up thing and is covering the $500 to have the shop replace it with a used one. First one I've heard of doing this in nearly 15 years of Subaru ownership.
De omnibus dubitandum.
Re: Do wheel bearings go bad from static loads? [Re: Deontologist] #5167881 07/22/19 07:51 AM
W
WyrTwister Offline
W
I thank God I do not live in the salt / rust belt !
Wyr
God bless
Re: Do wheel bearings go bad from static loads? [Re: Deontologist] #5167886 07/22/19 08:03 AM
J
JTK Offline
J
Just one wheel bearing?
They can go out before the car has 3yrs/36K miles on it. You just never know.
Just to add to the above, this could have been a manufacturing defect right out of the box, could be environmental factors or could have been caused by beating an old rotor off during a brake job. If it was a super cheap mail-order replacement wheel bearing, those could last 6 months, or 6yrs.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
