What is this??
by DriveHard - 02/28/20 09:45 AM
Ultimax 18" Build
by DriveHard - 02/28/20 09:42 AM
spray paint the wheel bead
by CNT - 02/28/20 09:40 AM
'What car should we get...'
by wings&wheels - 02/28/20 09:30 AM
Free entertainment at the gas station.
by Chris142 - 02/28/20 09:17 AM
Using Redline SL-1 as a Maintenance Dose
by Boomer - 02/28/20 09:08 AM
Oil changed yesterday on F150
by redhat - 02/28/20 07:30 AM
Intel or AMD Processor
by ZeeOSix - 02/28/20 04:02 AM
Denso Reman Starter Noise
by The Critic - 02/28/20 02:59 AM
Gratitude
by rrretiree7 - 02/27/20 11:56 PM
Maxlife for 35yo Ford C6
by Cubey - 02/27/20 11:35 PM
New 2-post lift on order
by clinebarger - 02/27/20 11:07 PM
New F-150 2.7 EB recommendations?
by mattri - 02/27/20 09:37 PM
Honey I bought a set of wheels
by P10crew - 02/27/20 09:29 PM
PQIA Pennzoil Hybrid 0W-16
by kstanf150 - 02/27/20 08:32 PM
100,000 ducks sent to Pakistan.
by Vern_in_IL - 02/27/20 08:07 PM
Shevretti, K9_zeke, hogryder007, Sabbag77, RpR
70821 Registered Users
90 registered members (4WD, 1978elcamino, bdcardinal, andyd, 440Magnum, alchargo, 6 invisible), 2,230 guests, and 16 spiders.
Topics302,036
Posts5,207,809
Members70,821
2008 Infiniti G37 P0011 and P0524 #5167562 07/21/19 06:23 PM
The Critic Online Crying OP
OP Online Crying
2008 Infiniti G37 with 80K miles. CEL is on, codes P0011 and P0524 were found. I wasn’t the one who diagnosed this one but supposedly, the oil pressure was tested and was found to be out of spec. The pressure was measured at ~10 psi.
This is a very common issue on the 08-12 VQ37 engines. Nissan used cork/paper gaskets on the oil gallery plates and these gaskets were prone to failure. The revised gaskets are now steel/cork and are no longer prone to failure. Accessing the oil gallery requires removing the timing cover and removing the primary timing chain. The job typically costs $4k at the dealer and $2500-$3K. Although the labor time for timing chain replacement is about 7 hours, most people will quote the labor time for engine removal which is 16 hours.
Unfortunately, during teardown, I found the spark plug for cyl #1 to be extremely fouled with oil deposits. For some reason this was not investigated during the initial diagnosis. Upon further inquiry, the customer said the plugs were only replaced 10K ago so this is a significant amount of oil deposits in a very short period of time. Instead of authorizing additional diag time, the customer elected to replace the engine with a used engine from a 2018 370Z; the used engine only has 7500 miles.
Note: As seen in the pictures, the timing components only had light varnish. However, the oil gallery plate screws had sludge and I also found sludge in some parts of the engine.
E41D944F-AF18-4EAB-9F62-0DF7E44BA0BB.jpeg75C7197C-1887-4EBD-8BA1-3E4423D4CCE0.jpegAFA96128-7DBB-473F-AE6D-8351FAD257FD.jpegF3A4586F-F738-438E-95EC-63AEA9BC5228.jpeg8C967FAB-503D-4F46-9D97-9C373232DDAA.jpeg0DB08333-9062-47D7-8CEB-A73A422FD5D9.jpeg427511EB-39FA-4F9D-AACF-6857EA6FA6A3.jpeg
2011 Toyota Prius 1.8L - 206K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 144K - Valvoline Premium Blue Restore 10W-30
Re: 2008 Infiniti G37 P0011 and P0524 [Re: The Critic] #5167570 07/21/19 06:34 PM
A
aquariuscsm Offline
A
Are there any differences between the 370Z and G37 engines performance wise?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 0W20
Re: 2008 Infiniti G37 P0011 and P0524 [Re: aquariuscsm] #5167681 07/21/19 09:15 PM
OP Online Crying
For the purposes of this repair, they are interchangeable.
Re: 2008 Infiniti G37 P0011 and P0524 [Re: The Critic] #5167938 07/22/19 09:10 AM
K
KGMtech Offline
K
It's sad that the old engine was allowed to sludge. I guess the paper gasket would have failed regardless of the maintenance schedule - being a 11 year old car.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
