Can I use 75w instead 70w gear oil?
by Polyalphaolefin - 02/28/20 11:57 AM
Alternative to Unaffordable New SUV?
by Fitz98 - 02/28/20 11:24 AM
What is this??
by DriveHard - 02/28/20 09:45 AM
Ultimax 18" Build
by DriveHard - 02/28/20 09:42 AM
spray paint the wheel bead
by CNT - 02/28/20 09:40 AM
'What car should we get...'
by wings&wheels - 02/28/20 09:30 AM
Free entertainment at the gas station.
by Chris142 - 02/28/20 09:17 AM
Using Redline SL-1 as a Maintenance Dose
by Boomer - 02/28/20 09:08 AM
Oil changed yesterday on F150
by redhat - 02/28/20 07:30 AM
Intel or AMD Processor
by ZeeOSix - 02/28/20 04:02 AM
Denso Reman Starter Noise
by The Critic - 02/28/20 02:59 AM
Gratitude
by rrretiree7 - 02/27/20 11:56 PM
Maxlife for 35yo Ford C6
by Cubey - 02/27/20 11:35 PM
New 2-post lift on order
by clinebarger - 02/27/20 11:07 PM
New F-150 2.7 EB recommendations?
by mattri - 02/27/20 09:37 PM
Honey I bought a set of wheels
by P10crew - 02/27/20 09:29 PM
ABchevy, RAOD, MichaelTx, duesenberg, Shevretti
70825 Registered Users
109 registered members (4WD, AlaskaMike, 2004tdigls, 01rangerxl, 53' Stude, Astro14, 9 invisible), 2,066 guests, and 18 spiders.
Topics302,039
Posts5,207,918
Members70,825
2017 Ram 1500 rear brake lines #5167296 07/21/19 12:27 PM
L
LAGA Offline OP
L
When replacing the rear rubber brake lines on a 2017 Ram 1500 4X4, does this part unscrew from itself. It’s where the hard line meets the rubber line?
Four legs good, two legs better!
Re: 2017 Ram 1500 rear brake lines [Re: LAGA] #5167306 07/21/19 12:33 PM
A
atikovi Online Content
Online Content
A
Looks like a standoff to keep it away from the body or axle. New part didn't come with one?
Re: 2017 Ram 1500 rear brake lines [Re: LAGA] #5167318 07/21/19 12:45 PM
L
LAGA Offline OP
L
The new part has the channel for the stand off. Looks totally different. It also might be the wrong part. Won’t know until I call tomorrow.
Re: 2017 Ram 1500 rear brake lines [Re: LAGA] #5167326 07/21/19 01:04 PM
A
Online Content
A
AC Delco has it.
[Linked Image]
Re: 2017 Ram 1500 rear brake lines [Re: LAGA] #5167336 07/21/19 01:14 PM
R
Rand Offline
R
This brings up the question why would you be replacing a brake line on a 2017? Car accident?
Re: 2017 Ram 1500 rear brake lines [Re: LAGA] #5167337 07/21/19 01:14 PM
L
LAGA Offline OP
L
Mine is a steel braided line from KLM, look different.
Re: 2017 Ram 1500 rear brake lines [Re: Rand] #5167338 07/21/19 01:16 PM
L
LAGA Offline OP
L
[replacing with steel braided lines for more more control towing.
Re: 2017 Ram 1500 rear brake lines [Re: LAGA] #5167484 07/21/19 04:35 PM
E
eljefino Offline
E
OT How is that 1/4" rod for holding that in place? I don't like putting my metal brake lines through repeated motions. Most brackets I've seen are more robust.
Re: 2017 Ram 1500 rear brake lines [Re: LAGA] #5167518 07/21/19 05:29 PM
A
Online Content
A
How does steel braided lines give more control? Should have all the control you need from the get go.
Re: 2017 Ram 1500 rear brake lines [Re: atikovi] #5167559 07/21/19 06:21 PM
L
LAGA Offline OP
L
First, it does not come apart there. It is one piece from factory. Replacement parts are two pieces.
Second, replacing rubber brake lines with steel braided reduces soft pedal feel. There is a big difference. Rubber lines expand under pressure. Also, less chance of of blowing a line under hard braking in an emergency.
Re: 2017 Ram 1500 rear brake lines [Re: LAGA] #5167593 07/21/19 07:01 PM
A
Online Content
A
For track use it may have a noticeable difference, but in normal street use, not significant. Same as drilled rotors. A lot of marketing hype.
Re: 2017 Ram 1500 rear brake lines [Re: atikovi] #5167666 07/21/19 08:45 PM
L
LAGA Offline OP
L
Obliviously you don’t tow a lot.
Re: 2017 Ram 1500 rear brake lines [Re: LAGA] #5167689 07/21/19 09:28 PM
clinebarger Offline
I tow a lot & never needed SS brake hoses.
2001 Chevy Camaro L92/4L80E
Re: 2017 Ram 1500 rear brake lines [Re: LAGA] #5167806 07/22/19 05:43 AM
skyactiv Offline
OP, what engine do you have in your Ram 1500 tow rig, a gas V6?
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: 2017 Ram 1500 rear brake lines [Re: Rand] #5167844 07/22/19 06:53 AM
W
WyrTwister Offline
W
I was wondering the same thing .
Wyr
God bless
