The OP, if they already have jumper cables, and a charger at home, could save some money buying just the lead acid jumper pack battery itself, rather than the whole lead acid jumper pack.
This is a 22Ah AGM (UB12220), but the same physical size of the 18AH agm (UB12180) that I have and which can start my 5.2 liter v8 engine all by itself. It weighs 2 Lbs more though. With lead acid batteries, heavier is better.
https://www.amazon.com/Universal-Po...d=1563772397&s=automotive&sr=1-6
I chose that specific link as it claims to be a replacement for a diehard jumper starter pack.
The
18 AH battery I bought is branded Mightymax and as a 600 watt battery, marketed for the stereo crowd, but Mightymax responded to just use the charging parameters of the Ub12180. I've no proof it is any different from the UB12180 branded as such.
I do wish I spent a bit more for this battery instead:
https://www.amazon.com/Mighty-Max-B...d=1563772904&s=automotive&sr=1-9
Some other batteries in the same size and general packaging, claim to be designed for high rate, that they have higher CCA. Until i actually have one to test and compared I will continue to have my doubts about many which appear the same.
The one below weighs more than others, or claims to anyway.
https://www.amazon.com/Yuasa-NPX-80...;qid=1563773255&s=gateway&sr=8-8
My first jumper pack nearly 20 years ago, was a Schumacher with a 12Ah AGM internal battery. When I removed the battery in '08, it actually said UB12120 on it, no high rate claims or anything. It did however have fatter stronger terminals than the other Ub12120 battereis I see online for as little as 25$.
It was good for several jump start assists on a overdischarged engine starting battery when newer, before requiring a recharge, and I used the internal single voltage charger back then as I did not know any better. i still have that wall wart somewhere. It is rated at 0.5 amps and would never go above 13.8v when attached to a 'fully charged' battery.
These lead acid jumper packs can safely be left attached to the main engine starting battery after jumping, to partially recharge it. Most Li-ion jumper packs to say to disconnect it withing a short period of time.
Many jumper packs with a 12v ciggy plug can be charged through that ciggy plug while driving, but it is highly unlikely that it will ever charge fully and certainly not quickly through such a limited, and generally poor connector and its wiring. The product below is an example, not a recommendation.
https://www.amazon.com/MOTOPOWER-MP...amp;s=gateway&sr=8-9-spons&psc=1
There are much better options for charging such a battery when driving, and this would basically be 10-2 low voltage landscape wiring, fused at 30 amps at the main engine battery, and fused again at the other end near the jumper battery. The battery would accept as much amperage as it wants at the voltage reaching its battery terminals. The voltage at the engine battery is what the vehicles voltage regulator commands and varies between 13.6 and 15 volts, depending on vehicl,e and some vehicles will range outside of this too, even when operating as intended. The 30 amps fuses could blow if the 10 awg wiring is short, when starting the engine.
The jumper battery should not be left connected to engine battery when the engie is not running.
Generally these jumper pack sized AGM batteries have a full charge resting voltage of ~13.15 volts, whereas flooded starting batteries are 12.8ish volts. The higher voltage jumper battery will feed the lower voltage battery until they both read the same, and it will degrade faster if left in parallel for a significant period of time.
As always it is important from a performance and longevity standpoint to return a discharged lead acid battery to full charge quickly after any amount of discharge. NO lead acid battery is immune to sitting partially discharged. The lower it is discharged and the longer it stays there the faster it will lose capacity and performance. It is like a shrinking gas tank. you can still fill it up, it just cannot store as much fuel.
