MolaKule
Staff member
Originally Posted by KneeGrinder
BigShug681 said:...I'm on the record, I've run atleast 1000 gallons of premix of AMSOIL at 100:1 in a yz490, and a watercooled, powervalve, cr250 that I raced on closed coarse tracks, never seized, and never any signs of abnormal wear that some are stating.
More than another 1000 gallons, closer to 2000 gallons of Golden Spectro at 50:1 in another cr250 race bike, no seize either, no signs of any abnormal wear. Golden Spectro is a blend meant for 50:1 and does not have any other solvents added like other 2 stroke oils do. There is a difference in 2 stroke oils!
In water-cooled power valve equipment I can see where a synthetic 2-cycle oil of a 100:1 mix could work. There has to be different formulations for different applications.
In small engine Outdoor Equipment, where the cooling fins might get obstructed with debris, such as sawdust or grass, and considering the cooling systems aren't all that great, 50:1 or 40:1 ratios might be more appropriate.
Some time ago I had an ancient Chain Saw that I purchased second handed, and due to its carbeuration set-up and it's piston-to-bore fit, it required an SAE SJ 30 grade oil and a 32:1 ratio or it wouldn't run. Until the engine got real hot, this puppy would smoke a mosquito fog.
My wife could always tell where in the woods I was from the smoke.
