LG Stove Top Gone Crazy
by Gebo - 04/09/20 09:28 AM
Newer Car Shopping List
by LazyDog - 04/09/20 09:19 AM
hand sanitizer
by matrass - 04/09/20 08:57 AM
Sludge concerns
by otis24 - 04/09/20 08:43 AM
Anyone Ever Have Their OEM rims Powder Coated?
by LoneRanger - 04/09/20 07:59 AM
Group 7 V2222
by GumbyJarvis - 04/09/20 03:56 AM
I'm looking for a 0w30 A5 B5 oil
by Marco620 - 04/08/20 11:57 PM
Does anyone put heat shrink tubing over a connector plug?
by motor_oil_madman - 04/08/20 10:39 PM
Anyone ‘excited’ for API SP/GF-6?
by addyguy - 04/08/20 10:30 PM
O'Reilly online learning for .gov email addresses
by spackard - 04/08/20 10:26 PM
Welding Helmet Fogging Up
by George7941 - 04/08/20 09:54 PM
Detroit 4-53T 2009 Ford F350 Update.:)
by A310 - 04/08/20 09:48 PM
Thoughts on CAFE standards
by otis24 - 04/08/20 09:20 PM
PUP amazon 5w-20
by Koncrete_Cam - 04/08/20 08:54 PM
Duralube Trans Shudder Fixx question
by soulburner - 04/08/20 08:36 PM
Number of Spare Magazines You Consider Adequate?
by 2015_PSD - 04/08/20 08:24 PM
Troy Bilt TB6044XP string trimmer dies when hot
by 92saturnsl2 - 04/08/20 07:18 PM
JD Yanmar deisel engine
by yankees1 - 04/08/20 07:14 PM
edot1, Tori, siroisma, i4ni, Monica
71133 Registered Users
126 registered members (aquariuscsm, 53' Stude, 4WD, 69Torino, alchargo, amblerman, 11 invisible), 2,303 guests, and 18 spiders.
Topics303,815
Posts5,242,394
Members71,133
Toyota 2AZ - FE!?? #5166670 07/20/19 08:23 PM
M
miden851 Online Content OP
OP Online Content
M
I was wondering what’s the community’s take on this engine; from I can see, it mostly runs all Toyota vehicle between 2002-2009; I’m familiar there is oil consumption on some of these engines but I don’t know what’s the time frame or what production years got affected by it; also, if someone would shed light upon, is there any other downside of the engine we should look at it please
So my friend is on the hunt for a Toyota with the same engine for around $5k that’s his budget; we have tested some vehicles today but we did not pull the trigger on it yet
As always, I thank for all constructive suggestions and advice!
2008 Mazda6i GT; @241K miles
2016 Honda CR-V EX-L; @56K miles
Re: Toyota 2AZ - FE!?? [Re: miden851] #5166705 07/20/19 08:54 PM
CR94 Offline
Originally Posted by miden851
...I’m familiar there is oil consumption on some of these engines but I don’t know what’s the time frame or what production years got affected by it...
You can find a lot of info, including complaints and service bulletins on line. The worst affected years were about 2007-2010, as best I can recall (which may not be exactly correct).
2011 Toyota Prius now at 110K
Re: Toyota 2AZ - FE!?? [Re: miden851] #5166890 07/21/19 03:12 AM
The Critic Offline
The early ones have issues with stripped head bolt threads in the block.
The later models (the ones that called for 5w20/0w20) had oil consumption problems. But the head bolt threads were no longer an issue.
2011 Toyota Prius 1.8L - 206K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 144K - Valvoline Premium Blue Restore 10W-30
Re: Toyota 2AZ - FE!?? [Re: miden851] #5166941 07/21/19 07:36 AM
M
OP Online Content
M
I thank you guys!
So, what year would be the best bet for this engine 2.4l in order to hopefully avoid a headache down the road if he decides to go with this route
Re: Toyota 2AZ - FE!?? [Re: miden851] #5166976 07/21/19 08:11 AM
A
ARCOgraphite Online Content
Online Content
A
Valve adjustment is a complete top end teardown on certain versions of this engine so make sure its not clattering
DOHC with mechanical shim under bucket inverted tappets ala earlier nissan style. I had about 7 valves way out of spec (wide) on ours by 56K miles. I think toyota wanted near $1700 to re-clearance the lash.
2005 rav4
Ours was using about a quart per OCI. This was with MC5000 5w30 dino at 5K intervals and Toyota denso filters.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Toyota 2AZ - FE!?? [Re: miden851] #5166987 07/21/19 08:20 AM
E
eljefino Offline
E
I took my mom's 02 camry to 240ish k with zero engine issues. If it burned oil it was a negligible amount. I went easy on it during warm-up as I think she did as well.
I flipped another 02 camry with 200k-- came with a VVTi code but an oil change cleared out the solenoid and it too ran just fine.
I think it's a very nice motor, especially in front of a stick shift. Only issue I have is the electric throttle is a little crabby in the cold in 1st gear, and it wasn't something solvable by cleaning.
I think this "head bolt" thing is something that's barely statistically significant, but people are able to latch on to it via the internet amplification effect. "That sounds like an expensive part of the engine" they think.
I've been driving "mediocre" used cars (think saturn s-series) since forever and let their mediocrity run the price down so they're a good value. In my neighborhood Toyota sedans of a certain vintage are a dime a dozen. (Trucks and SUVs still have sky high values.)
Re: Toyota 2AZ - FE!?? [Re: miden851] #5167032 07/21/19 08:59 AM
L
LeakySeals Offline
L
I'm very familiar with that engine. I had a 02 Camry auto with the 2AZ-FE for several years. The motor blew on the highway. Broke a valve. Burned up, chipped, fell down in the cylinder. Oil consumption caused that. A combination of bad valve seals and clogged piston oil return holes. Burning 1 qt every 1500 over 150k miles eventually takes its toll. I replaced the seals and it did the same thing to the second set. Its heat. The aluminum block is real thin. The thin block and heating leads to other problems. If you google "stripped head bolt 2AZ-FE" you will see a HUGE problem with that engine. The thin aluminum block gets real hot, and the block threads let go. The head separates causing a massive coolant loss. In later years the oil consumption got so bad they issued a TSB for modified pistons with larger oil return holes.
It was never smooth. Always shaking, rattling at startup, burning oil. In my opinion there is no good year for that engine. You're better off with the 6 cyl. Smoother, stronger. Within 2 mpg of the 4 cyl.
06 Escalade 6.0L LQ9 AWD 170k M1 5w30
03 Maxima 3.5L 170k Maxlife HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
06 Altima 2.5L 167k unk
Re: Toyota 2AZ - FE!?? [Re: miden851] #5167155 07/21/19 11:08 AM
supton Online Content
Online Content
I'd avoid the 2AZ-FE for the reasons stated. I get eljefino's point but I don't like taking gambles. Maybe on a car for the kids that I got cheap and would be ok with tossing if a repair exceeded that which I was comfortable with, but for my own daily driver I'm pretty gun-shy on this engine. The preceding 5S-FE seems better (reliability wise, not on power or mpg, and they're old now) and the succeeding 2AR-FE seems to be what people think a Toyota ought to be (not having these issues).
2011 Toyota Camry, base, 2.5L/6MT, 203k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 158k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: Toyota 2AZ - FE!?? [Re: miden851] #5167197 07/21/19 12:06 PM
J
JustinH Offline
J
Have a 2011 XB with this engine, it has been typical Toyota boring with good service.
Change oil every 4500-5000 miles with whatever dino is on sale, and it uses about half a quart in 5000 miles.
Ours has 88k now.
'16 Ford Escape
'11 Scion XB
Re: Toyota 2AZ - FE!?? [Re: miden851] #5167359 07/21/19 02:45 PM
H
HangFire Offline
H
A friend has one in an 09 Camry approaching 150K miles, gets regular service on schedule, and has zero problems. But I know some people have had problems with them.
Various musings: http://hangfire.net
Re: Toyota 2AZ - FE!?? [Re: JustinH] #5167385 07/21/19 03:23 PM
blupupher Offline
Ours has 88k now.
Supposedly fixed the issues by 2011.
I also have an xB with this motor and have had no real issues in 50,000 miles (but that is when the oil burning tends to start according to many).
Mine goes through ~1/2 qt in 5000 miles (although last change I was down almost a qt, but had a small drip from the oil filter).
'18 Santa Fe: PP 10W30/OEM
'18 Soul: Synpower 5W30/ProGuard
'12 xB: M1 EP 0W20/CQ Blue
'10 Santa Fe: Synpower 5W30/D+
'04 F150: Magnatec 10W30/ST
'02 F150: Magnatec 5W20/D+
'94 VT1100: Peak 15W40/D+
