Fram Xg3682 for ISO 32 🛠
by SavagePatch - 04/05/20 11:58 AM
Honda V6 PCV Valve - Steel Bolt
by SWS - 04/05/20 11:50 AM
Ford Fusion wiper blade question
by Corollaman - 04/05/20 11:05 AM
Is this stainless steel?
by atikovi - 04/05/20 10:45 AM
Skyactiv 2.5L - Oil Capacity
by buster - 04/05/20 10:42 AM
3/4" hose
by CNT - 04/05/20 10:29 AM
Westinghouse iGen 4500 Generator
by SailSkiDrive - 04/05/20 09:16 AM
Generac Power Washer Engine Oil Type.
by Andya - 04/05/20 08:49 AM
Barrs leak oil additive
by Micahmcmeen - 04/05/20 08:10 AM
Lawn mower oil question
by icemanrrc - 04/05/20 08:10 AM
Wait until you see who's driving...
by Shannow - 04/05/20 06:57 AM
Getting My Harley Back On The Road
by Silverado12 - 04/05/20 06:45 AM
Oil brand you've never used
by OilUzer - 04/05/20 02:27 AM
New dishwasher on order...
by gregk24 - 04/05/20 12:19 AM
Blueing steel
by koffy - 04/04/20 11:53 PM
Home electrical question.
by 73guna - 04/04/20 10:20 PM
daniell, carguy1701, London, Dave66, Kurt_Kent_09
71104 Registered Users
95 registered members (Ag76, 77GrandPrix, 007, 2015_PSD, 2009Edge, 4WD, 9 invisible), 2,693 guests, and 18 spiders.
Topics303,629
Posts5,238,673
Members71,104
Injector sleeves in 7.3 Powerstroke w/ 6 sp MT #5165912 07/19/19 11:32 PM
E
Earls1st Offline OP
E
Fuel over-filling the coolant tank and present in engine oil. Approx 125000 miles on the motor. Does this require head removal to diagnose? Are injector sleeves and fuel cups both terms for the same thing? Can the old sleeves be removed and replaced without removing the heads? Is there some maintenance I missed to cause this problem? Does driving style cause this problem? Can fuel additives either prevent or hasten the development of this problem?
Re: Injector sleeves in 7.3 Powerstroke w/ 6 sp MT [Re: Earls1st] #5165940 07/20/19 12:36 AM
clinebarger Offline
It just happens, They are made of Brass & can crack. I've always called them Injector Cups.....
My removal/installation tools are OTC & makes the job possible without removing the cylinder heads, Probably some cheaper tools available! Use OE Ford Cups & Injector seal kits!!!!!!
If the fuel is left in the cooling system long enough......It ruins EVERYTHING that's made of rubber along with anything with a rubber seal.
Radiator
Heater core
All coolant hoses
Water pump
Radiator cap
Most just replace the offending cup.....I highly recommend replacing all 8!!
2001 Chevy Camaro L92/4L80E
Re: Injector sleeves in 7.3 Powerstroke w/ 6 sp MT [Re: clinebarger] #5166037 07/20/19 07:20 AM
M
mattd Online Content
Online Content
M
Yes it can be done heads on engine but it’s not the easiest. Do all 8. You’ll need a remover and installer and some specialty green loctite. As far as something you could have done to prevent this, not really no. They just crack over time. I would drive the truck like this at all if it’s overfilling the coolant explanation tank. As Cline said, you’ll need replace everything rubber in the cooling system, flush the radiator and heater core at minimum and replace the water pump.
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: Injector sleeves in 7.3 Powerstroke w/ 6 sp MT [Re: Earls1st] #5166468 07/20/19 04:41 PM
bdcardinal Offline
Fairly common, we do them occasionally. Not as much as when I first started in 2007, but still do them. You will need the remover/installer as well as the correct green Locitie. Fortunately the parts aren't expensive.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Injector sleeves in 7.3 Powerstroke w/ 6 sp MT [Re: Earls1st] #5166588 07/20/19 06:53 PM
M
Online Content
M
My post was meant to say NOT drive the truck . Sorry phone sucks
ASE Master, L1, L2
