I wouldn't "waste" the money on Amsoil if you're having to add a quart every 1500 miles. That will be super expensive with no real benefits. To me, Amsoil really only makes financial sense if you can do the oil change and not have to add any new oil until you're draining it. If I were in your shoes, to keep the cost down and still protect the engine:
Buy QSUD 5w30 jugs from Walmart
Use Fram Ultra filter
Add 1 quart every 1500 miles
Change filter every 20k
Never perform a "normal" OCI again because your sump is being turned over about every 7k miles anyway since you are constantly refreshing the additives and TBN. Your engine will still be protected just fine.
