Corona Virus and Car Sales?
by Vern_in_IL - 02/26/20 07:34 PM
Emblem Adhesive Recommendation
by Fitz98 - 02/26/20 07:18 PM
Drain Plug Washer Frozen to Oil Pan
by CrackyWainwright - 02/26/20 06:31 PM
ams OE 0/20 6100 mi 14 KIA 2.4L GDI
by pair of Blazers - 02/26/20 06:17 PM
Any Exotic Brand Dealership Mechanics Here?
by john_pifer - 02/26/20 06:14 PM
Sentra no start
by Aredeeem - 02/26/20 06:07 PM
Sync Update 2016 Cmax
by borgward - 02/26/20 03:30 PM
Kirkland 0w20 at local Costco
by paulri - 02/26/20 03:12 PM
LG Red in a VW DSG trans?
by racin4ds - 02/26/20 02:31 PM
2013 Jaguar XF 3.0 AWD
by ET16 - 02/26/20 02:25 PM
Ford....in trouble??
by earthbound - 02/26/20 01:31 PM
Interesting read
by double vanos - 02/26/20 10:51 AM
2010 Honda Element 127K miles valvetrain picture
by SLO_Town - 02/26/20 10:01 AM
Anyone Used a Sea Sucker Bike Rack/Mount?
by jcartwright99 - 02/26/20 09:46 AM
8 passenger vehicle typically 5 for <=$15k
by madRiver - 02/26/20 09:27 AM
RON Octane Gasoline rating
by Building3 - 02/26/20 09:26 AM
Who makes Canadian Supertech?
by Patman - 02/26/20 09:08 AM
Scotts994Runner, Bu33leGutz, splitthebreak, shadango, JimNastic316
70808 Registered Users
137 registered members (55hambone, 2003f7, 5AcresAndAFool, 4WD, Aichiguy, Avery4, 14 invisible), 1,999 guests, and 15 spiders.
Topics301,961
Posts5,206,437
Members70,808
Are these bushings rubber or poly? And what grease? #5166532 07/20/19 04:55 PM
O
OCDriver Offline OP
O
I bought a set of these for my stabilzer bar and I can't tell whether they're rubber or polyurethane. Google and manufacturer's website are no use.
Do I need to grease them for installation? What type of grease should I use?
Re: Are these bushings rubber or poly? And what grease? [Re: OCDriver] #5166545 07/20/19 05:09 PM
Danno Offline
My call is a dry install.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: Are these bushings rubber or poly? And what grease? [Re: OCDriver] #5166609 07/20/19 06:14 PM
M
Mainia Offline
M
I would use this aluminum oxide grease, 100% waterproof and far better then lithium grease. It is compatible with common cheap yucky lithium grease. Coffee2
https://www.amazon.com/Schaeffer-Ma...d=1563667924&s=industrial&sr=1-2
2018 Lowered Hyundai Kona AWD 1.6T
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: Are these bushings rubber or poly? And what grease? [Re: OCDriver] #5166619 07/20/19 06:25 PM
T
Trav Offline
T
Not poly but a synthetic rubber. Use this, you can find it at AA, AZ, NAPA, etc.
https://www.amazon.com/CRC-05359-Ca...&hvtargid=pla-435202304337&psc=1
Edit: Do not install dry it may squeak.
Re: Are these bushings rubber or poly? And what grease? [Re: OCDriver] #5166640 07/20/19 06:57 PM
M
maxdustington Offline
M
Anti sieze.
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: Are these bushings rubber or poly? And what grease? [Re: OCDriver] #5166652 07/20/19 07:10 PM
O
OCDriver Offline OP
O
4 replies, 4 different answers, true to BitOG form :p
If I grease them, can I just use Mobil1 GC-LB synthetic grease I have? Says it's meant for chassis components.
Re: Are these bushings rubber or poly? And what grease? [Re: OCDriver] #5166717 07/20/19 08:06 PM
M
M
Silicone or AS only, I reckon. Sway bar bushings seem to be prone to creaking. I'm not sure if it's washout that causes it or what.
PUP 5W30/Ultra
Re: Are these bushings rubber or poly? And what grease? [Re: OCDriver] #5166740 07/20/19 08:31 PM
G
Gebo Offline
G
I'd go with Trav thumbsup
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Are these bushings rubber or poly? And what grease? [Re: OCDriver] #5166751 07/20/19 08:39 PM
T
Trav Offline
T
The stuff I linked to is silicone based with solid lubricants, I have had bushings in cars for many years with the stuff and never had any sort of reaction or noise. It has safe for rubber right on the can.
Re: Are these bushings rubber or poly? And what grease? [Re: OCDriver] #5167192 07/21/19 10:46 AM
doitmyself Offline
Not that it matters, but when I investigated brake grease some years ago, I got the impression that the CRC product was a PAO base, not silicone. As long as it works, that is what is important.
Re: Are these bushings rubber or poly? And what grease? [Re: OCDriver] #5167679 07/21/19 09:11 PM
O
OCDriver Offline OP
O
Thanks everyone, I went with a dry install since these were rubber bushings. No squeaks or anything, and the clunks are gone! smile
Re: Are these bushings rubber or poly? And what grease? [Re: OCDriver] #5167707 07/21/19 09:54 PM
Y
Y_K Offline
Y
Poly is horrible if your winter temps are low
Re: Are these bushings rubber or poly? And what grease? [Re: OCDriver] #5167766 07/22/19 03:48 AM
A
alcyon Offline
A
Super Lube
Kyosho Optima Mid SWB, LWB and Lazer ZX
1991 Proton Saga 1.3S SOLD
1989 Toyota Soarer GT Twin Turbo L
1985 Kuwahara Survivor
1992 Robinson Pro
Re: Are these bushings rubber or poly? And what grease? [Re: OCDriver] #5168095 07/22/19 12:20 PM
O
OCDriver Offline OP
O
One follow-up question: the bushings are split so they can just be slipped on around the bar. I made sure the bar is centered and correctly oriented, and positioned the bushings the same as the old ones, but one of the bushings doesn't totally close up. Is this a problem? It doesn't seem to affect performance.
