Is it worth its weight in cast iron?
by spavel6 - 07/06/20 03:42 PM
Hyundai O.E.M. 28113-H8100 replacement
by odie - 07/06/20 03:22 PM
Valvoline SynPower Power Steering Fluid
by Cheezit - 07/06/20 03:17 PM
Shell Rotella Gas Truck or Pennzoil?
by DCMotorsports - 07/06/20 02:49 PM
Interesting domino game
by 53' Stude - 07/06/20 02:49 PM
Grinding brakes when hot
by mclasser - 07/06/20 02:41 PM
Nylon spacers
by VeeDubb - 07/06/20 02:37 PM
Extra Long Valve Caps
by Mr_Luke - 07/06/20 02:28 PM
using vinegar to flush cooling system
by old1 - 07/06/20 02:11 PM
Best lube for refrigerator door hinges?
by paulri - 07/06/20 01:11 PM
RIP Ennio Morricone
by 2015_PSD - 07/06/20 12:49 PM
What oil do you recommend?
by BretBouer - 07/06/20 12:36 PM
NAPA Synthetic / Filter Sale
by WyrTwister - 07/06/20 12:16 PM
Squished Stihl MS 181
by Gebo - 07/06/20 12:14 PM
Used Review- '17 Nissan Armada Platinum
by panthermike - 07/06/20 11:53 AM
RIP Charlie Daniels.
by PimTac - 07/06/20 11:34 AM
Transmission fluid change
by dan765 - 07/06/20 10:53 AM
Toyota LL or SLL in a Ford?????
by TacoFergie - 07/06/20 10:52 AM
Pulling a vacuum to remove water
by Donald - 07/06/20 10:42 AM
Colt_38, DCMotorsports, BryceMateo, Dodgerose, AnotherPerson
71862 Registered Users
104 registered members (2015_PSD, 53' Stude, 4WD, 928, 97prizm, 77GrandPrix, 9 invisible), 2,417 guests, and 20 spiders.
Topics307,502
Posts5,312,226
Members71,862
Page 2 of 2 1 2
Re: Which 0W20 to slow use [Re: lukejo] #5166174 07/20/19 10:01 AM
L
lukejo Offline OP
L
It’s a 2AR—FE.
PVC replaced with OEM, made no difference.
Absolutely no leaks.
Never smokes on start-up.
So...do you think it’s only consuming oil at lengthy trips of high speed? Again, it’s driven lots of miles, all highway of about 70mph.
Rate of oil consumption has not changed for at least 50k miles.
If only burning when it’s at speed and never smoke at start-up, would 0w-30 make more sense...at least keeping the 0w part of Toyota’s recommendation?
(I know 0w-30 can be hard to find, but we’d just try Amsoil SS since we already use their small engine stuff for our business equipment)
Re: Which 0W20 to slow use [Re: lukejo] #5166191 07/20/19 10:12 AM
L
lukejo Offline OP
L
Then again, looking at the SS formulas’ chart, their 5w-20 has a NOACK of only 5.8!
(Who knows if NOACK would make any difference in consumption in this situation though...)
Re: Which 0W20 to slow use [Re: lukejo] #5166201 07/20/19 10:23 AM
A
aquariuscsm Offline
A
Shell Australia says you can use 0W20-15W40 in your car.
I would use either a 5W or 10W30.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum High Mileage 10W30
Re: Which 0W20 to slow use [Re: lukejo] #5166228 07/20/19 10:44 AM
B
benjy Offline
B
as noted 5-30 in winter + 10-30 in summer as the xx-20's prolly wore the engine sooner than a xx-30 would have! as said many times by many people xx-20 is for a minute mpg gain while EPA testing, stop-start is similar!
Re: Which 0W20 to slow use [Re: benjy] #5166229 07/20/19 10:45 AM
I
Imp4 Offline
I
Oh brother....
Re: Which 0W20 to slow use [Re: lukejo] #5166235 07/20/19 10:50 AM
SubieRubyRoo Offline
I wouldn’t “waste” the money on Amsoil if you’re having to add a quart every 1500 miles. That will be super expensive with no real benefits. To me, Amsoil really only makes financial sense if you can do the oil change and not have to add any new oil until you’re draining it. If I were in your shoes, to keep the cost down and still protect the engine:
Buy QSUD 5w30 jugs from Walmart
Use Fram Ultra filter
Add 1 quart every 1500 miles
Change filter every 20k
Never perform a “normal” OCI again because your sump is being turned over about every 7k miles anyway since you are constantly refreshing the additives and TBN. Your engine will still be protected just fine.
De omnibus dubitandum.
Re: Which 0W20 to slow use [Re: lukejo] #5166304 07/20/19 12:07 PM
A
aquariuscsm Offline
A
I'll be interested to see if your oil usage halts once you start using a W30.
Re: Which 0W20 to slow use [Re: lukejo] #5166319 07/20/19 12:38 PM
J
JEL01 Online Content
Online Content
J
You can find 0w30 M1 AFE at wally pretty cheaply and easily if you want to go that route
Cars I maintain:
02 Mercedes CLK430
09 Honda Accord V6
13 Lexus RX350 AWD
02 Toyota Tundra 4x4
18 Lexus GX460
Re: Which 0W20 to slow use [Re: lukejo] #5166393 07/20/19 02:54 PM
dave1251 Offline
Try a HM 5W30.
don't use.
Re: Which 0W20 to slow use [Re: lukejo] #5166566 07/20/19 06:29 PM
Direct_Rejection Offline
Originally Posted by lukejo
2012 Camry. 199,000 miles. All highway driving. Having to add 1 quart every 1,500 miles. No leaks. Have tried both PP and M1 in EP and AP, and usage was the same.
If I want to stay in grade, do you think any other brands would do any better?
See signature. Valvoline Restore before Illinois winter arrives. Then EDGE HM 0W20 from Walmart. Your problem is obviously piston ring coking and/or valve stem seal wear.
The EDGE has a low phosphorus add pack, just like green bottle HM. Constantly top off and pass smog checks. That's what I see in your future.
I have lived this several times. Toyota 4 bangers start consuming oil around 150k-250k miles. I have logged 1.5 million miles + on Toyota 4 bangers. Your engine has a high propensity for this issue.
My $0.02 ...
2019 Lexus UX 250h F-Sport
HPL HD 0W16 SL
@ 61k miles
Re: Which 0W20 to slow use [Re: lukejo] #5166816 07/20/19 10:57 PM
T
ThirdeYe Offline
T
My Accord burns about a quart every thousand. It’s extremely consistent and the brand/weight seems to make no difference at all. I’ve tried conventional, synthetic blend, synthetic, 5w20, 5w30 and 10w30 with no difference. I assume it’s due to the oil control rings and as such, the weight really shouldn’t make a difference based on my research. Granted, mine has over 3 times as many miles as yours. No leaks or visible burning aside from some discoloration on the bumper. I had a Scion tC before this with the notorious 2AZ-FE ring issue and the brand/weight also made no difference in that car.
07 Honda Accord - 627k - Pennzoil Ultra Platinum 5W-20/Wix 57356
98 Camaro Z28 (Bright Purple Metallic, 1 of 104) - 127k - Mobil 1 HM 5W-30/Fram Pro Synthetic XG3506
Page 2 of 2 1 2
