AFAIK, the current aluminum keyboard(the one that you recharge using an iPhone charger cable) uses the garbage butterfly mechanism. That's most likely your problem.
If you want wireless and the "Apple Look", find one of the older ones that runs on AAs, which uses the much better scissors mechanism. If wireless isn't mandatory but you still want the look, go for the wired version of that keyboard, which has the novel feature of a numeric keypad
Personally, I don't have much use for any current Apple keyboard(and I'm typing this from a MacBook Pro that is old enough to have scissors). On my Mac Pro(5,1) at home, I use an ancient Apple Extended Keyboard with cream Alps switches(mechanical) via a Griffin iMate. My work Mac Pro(1,1) has a Unicomp Spacesaver M, which is a USB keyboard based on the IBM Model M chassis but with Mac-specific keys. The Model M uses a "buckling spring" mechanism with a distinctive, sharp click and a key feel like no other. I actually prefer the Model M, and keep meaning to buy one for use at home
https://www.pckeyboard.com/page/category/SpacesaverM
BTW, I have used Windows/PC keyboards with Macs before. I've even used 101-key keyboards, although a key remap and some thought is necessary if you're a heavy user of the control/option/command keys(I am).
