Bosch Premium 3410
by QuangTeo - 04/01/20 03:48 AM
Thicker oils are coming back to USA
by Kamele0N - 04/01/20 03:07 AM
misty air coming out of air hose even with water separator?
by motor_oil_madman - 03/31/20 11:22 PM
Post your favorite racing cars
by IMSA_Racing_Fan - 03/31/20 09:40 PM
Air Filters for Chonda 457cc engine
by 92saturnsl2 - 03/31/20 07:59 PM
Share your Hot Toddy recipe
by LoneRanger - 03/31/20 07:24 PM
Aftermarket CV axle boot replacement
by CDX825 - 03/31/20 06:34 PM
A few discounts at Walmart for buying 2 jugs
by jayjr1105 - 03/31/20 06:20 PM
Bumblebee Ahi tuna poke
by atikovi - 03/31/20 06:05 PM
2007 RDX Differential and Transfer Case?
by maverickfhs - 03/31/20 06:02 PM
Tacky additive in bar and chain oil
by TreyT42 - 03/31/20 05:02 PM
How Come Diesel is $2.69 when gas is $1.47 ?
by LoneRanger - 03/31/20 04:42 PM
Bosch Premium 3422 Cut Open
by getawheel - 03/31/20 03:52 PM
AC Went out in my Forester Again
by Miller88 - 03/31/20 03:48 PM
I'm out on the Front Porch
by MolaKule - 03/31/20 03:11 PM
Raybestos rotors - Element3 vs Specialty Truck
by RageOfFury - 03/31/20 02:39 PM
Briggs Stratton Quantum engine surging
by alex_at - 03/31/20 12:53 PM
Are harbor freight generators any good?
by NavyVet88 - 03/31/20 12:37 PM
A picture of me in my youth! :-)
by SLO_Town - 03/31/20 11:18 AM
Rickborn, TreyT42, Abi, Transpections, burgM
71068 Registered Users
64 registered members (18LateModelFan, 4WD, AlienBug, 94astro, aquariuscsm, alex_at, 7 invisible), 1,386 guests, and 22 spiders.
Topics303,527
Posts5,235,895
Members71,068
Which 0W20 to slow use #5165898 07/19/19 11:09 PM
L
lukejo Offline OP
L
2012 Camry. 199,000 miles. All highway driving. Having to add 1 quart every 1,500 miles. No leaks. Have tried both PP and M1 in EP and AP, and usage was the same.
If I want to stay in grade, do you think any other brands would do any better?
Re: Which 0W20 to slow use [Re: lukejo] #5165904 07/19/19 11:17 PM
B
burla Offline
B
200k miles, consider going out of grade or shop low noack oils.
Re: Which 0W20 to slow use [Re: lukejo] #5165924 07/19/19 11:49 PM
J
JEL01 Offline
J
When my Honda was using almost that much 5w20 I bumped up to 5w30 HM (various brands) and all substantially reduced burning with no fuel economy hit
Cars I maintain:
02 Mercedes CLK430
09 Honda Accord V6
13 Lexus RX350 AWD
02 Toyota Tundra 4x4
18 Lexus GX460
Re: Which 0W20 to slow use [Re: lukejo] #5165929 07/20/19 12:03 AM
T
tiger862 Offline
T
Try Havoline high mileage or Valvoline Advanced High Mileage 0w20. Both would be in grade with Valvoline Advanced with Maxlife would get nod.
Tiger862
2018 Grand Caravan
Re: Which 0W20 to slow use [Re: lukejo] #5165938 07/20/19 12:35 AM
SR5 Online Content
Online Content
A 7 year old Camry with almost 200k miles. Easy !!
5W30 In winter and 10W30 in summer.
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: Which 0W20 to slow use [Re: lukejo] #5165969 07/20/19 02:32 AM
Dylan1303 Offline
PPHM 0w20
12 cruze rs 1.4t 6spd pp 5w30 tuned on 22psi
19 cruze auto 1.4t amsoil oe 5w20 tuned on 24psi
Re: Which 0W20 to slow use [Re: lukejo] #5165971 07/20/19 02:40 AM
SR5 Online Content
Online Content
BTW the Australian spec for the Toyota Camry with the 2.5 Litre 2AR-FE VVT-I is 0W20, 5W30, 10W30 or 15W40 take your pick.
Is that the engine you have ?
Re: Which 0W20 to slow use [Re: lukejo] #5165980 07/20/19 03:35 AM
N
Nederlander75 Offline
N
0w20 is the Devil.
Re: Which 0W20 to slow use [Re: lukejo] #5165983 07/20/19 04:21 AM
demarpaint Offline
I'd bump up a grade as others suggested.
God Bless Our Troops
Re: Which 0W20 to slow use [Re: lukejo] #5165999 07/20/19 05:37 AM
R
Rolla07 Offline
R
Use a HM oil.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: Which 0W20 to slow use [Re: lukejo] #5166008 07/20/19 06:01 AM
T
Tjbouwhu Offline
T
I have always been reluctant to move too far from OEM oil recommendations. From Amsoil web site:
https://blog.amsoil.com/what-happens-if-i-use-the-wrong-weight-viscosity-of-oil/
Yet, as was pointed out earlier, auto manufacturers seem to have different oil recommendations for the same engine in different countries???
I don’t understand...
Tom
Re: Which 0W20 to slow use [Re: SR5] #5166038 07/20/19 07:21 AM
53' Stude Offline
I believe his is the 2AZ-FE same as in my 2009 Camry
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: Which 0W20 to slow use [Re: lukejo] #5166045 07/20/19 07:27 AM
H
HowAboutThis Offline
H
I'd make sure I knew why it was losing oil. A lot of miles? PCV valve? Leaking filter? Some variable valve timing thingy seal like my Honda used to enjoy leaking from? Etc.
If it's just a lot of miles, heavier grade as some said might help. Or HM oil. Otherwise, a quart every 1500 isn't bad for 200k.
If it's from something leaking and not just a wearing engine, then fix that and keep using 0w20.
Re: Which 0W20 to slow use [Re: lukejo] #5166060 07/20/19 07:45 AM
P
PowerSurge Offline
P
Try Toyota Synthetic oil. I know it’s made by Mobil, but it seems to not burn off at the same rate as Mobil 1. I have an old Honda I use as a daily beater and I never have to add oil between changes and it has over 220,000 miles. My dealer (4.25 quart) sells it a lot cheaper than Amazon.
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra and a few others
Re: Which 0W20 to slow use [Re: lukejo] #5166126 07/20/19 08:59 AM
danez_yoda Offline
Does it smoke when you start or while running?
Do you see oil drips on the ground?
Have you changed your PCV ever? That could cause oil consumption as well.
If none of these things apply put some 5W30 in for one OCI or 5K miles and see if the consumption goes down. Maybe a 0W-30 but it is harder to find.
