Monaco GP 1992 Senna/Mansell Battle
by IMSA_Racing_Fan - 04/07/20 03:03 AM
RV's for MD's
by 02SE - 04/07/20 01:42 AM
Crawfish, It's A Louisiana Thang!
by BlueOvalFitter - 04/07/20 01:01 AM
M&P .40 Magazines $12.99
by BlueOvalFitter - 04/06/20 11:30 PM
Lots of Big Sur pics, only one of the car :-)
by SLO_Town - 04/06/20 09:24 PM
'16 Pilot Inline ATF filter
by parshisa - 04/06/20 08:55 PM
2019 Ram 1500 Classic
by Skippy722 - 04/06/20 08:53 PM
STP S3614 XL CUT OPEN
by 53' Stude - 04/06/20 07:15 PM
Kia Rio awful sound after sitting 5 years
by antonmnster - 04/06/20 07:13 PM
Cut open Motorcraft FL820S
by PantherFan88 - 04/06/20 06:38 PM
240V Electric Hookup Questions
by 92saturnsl2 - 04/06/20 06:33 PM
license plate frame with 3rd brake light
by wings&wheels - 04/06/20 06:12 PM
Wurth HHS 2000
by ejt - 04/06/20 06:06 PM
Snapper drive belt install trouble LT300
by spk2000 - 04/06/20 05:56 PM
installing garage LED shop light help needed
by FirstNissan - 04/06/20 05:20 PM
Casite filters
by opus - 04/06/20 05:16 PM
Oil for Jeep
by rokwldr - 04/06/20 05:12 PM
Kitchen sink faucet leak help
by 97prizm - 04/06/20 04:45 PM
RIP Al Kaline.
by PimTac - 04/06/20 04:36 PM
Frankentruck power steering question
by Thomcat316 - 04/06/20 04:11 PM
BludRacing, Cacciatore, Thomcat316, NTexian, LateLifeCrisis
71116 Registered Users
34 registered members (bbhero, Bonz, Amkeer, alchargo, Billy101, Bookmaker, 5 invisible), 1,357 guests, and 16 spiders.
Topics303,701
Posts5,240,246
Members71,116
Yanmar marine 6lya-stp Needs Flush (or more)!! #5165853 07/19/19 09:48 PM
Capt Offline OP
I am dealing with a customer boat 2007 Yanmar 6lya-stp 370hp with a neglected cooling system. I tried to drain coolant from block petcock and not a drop.. after inserting 6'' screw drivers into hole came nothing but brown hard sludge... not a drop of liquid! Upper coolant reservoir & heat exchanger top showed rusty brown water, not pretty.
It should be flushed several times to operating Temp & filed with a O.A.T. ELC or Dexcool per Yanmar specs.
What would be a good product to remove sludge buildup???
This engine ran 30 hrs at 80% (2800 rpm) power 400 miles just a few months ago @ 170F with no issues, but I think its a ticking time bomb...
any suggestions?
Thanks,
Capt
Re: Yanmar marine 6lya-stp Needs Flush (or more)!! [Re: Capt] #5165866 07/19/19 10:03 PM
R
Rand Offline
R
non marine engines I'd use prestone super flush or citric acid.
but I dont work on closed system marine engines...
Re: Yanmar marine 6lya-stp Needs Flush (or more)!! [Re: Capt] #5165883 07/19/19 10:35 PM
M
mattwithcats Offline
M
Go by a hardware store, pick up a box of Tri Sodium Phosphate, TSP...
Add 1/2 to 1 tablespoon per gallon of system capacity...
Also consider installing a coolant filter if possible...
https://en.m.wikipedia.org/wiki/Trisodium_phosphate
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Yanmar marine 6lya-stp Needs Flush (or more)!! [Re: Capt] #5165960 07/20/19 01:57 AM
L
Linctex Offline
L
White vinegar and citric acid are mentioned al the time.
Cascade automatic dishwasher soap also cleans well.
A closed loop system marine engine shouldn't be too much different than a car/truck.
Does the big Yanmar use dry sleeves or wet sleeves?
Re: Yanmar marine 6lya-stp Needs Flush (or more)!! [Re: Capt] #5166115 07/20/19 08:47 AM
B
bullwinkle Offline
B
I'm guessing something bad has happened-major cooling system leak through the heat exchangers-or worse?
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Yanmar marine 6lya-stp Needs Flush (or more)!! [Re: Capt] #5166308 07/20/19 12:13 PM
Capt Offline OP
Not Sure about the sleeves. I believe the issue is from old coolant or possibly mixing of incompatible coolants as I noticed a jug on the boat with a missing label, who knows... We have not noticed any coolant loss or gain so hopefully the system is still intact, I will probably do a leak down test. I will start with an automotive radiator flush and report back. Thanks -capt
Re: Yanmar marine 6lya-stp Needs Flush (or more)!! [Re: Capt] #5167086 07/21/19 09:56 AM
R
roadrunner1 Offline
R
FleetGuard make a product, Restore/Restore+ for cleaning cooling systems. I've used it and it works very well.
'15 F350 6.7
Re: Yanmar marine 6lya-stp Needs Flush (or more)!! [Re: roadrunner1] #5168472 07/22/19 09:28 PM
Capt Offline OP
Hello all, I was able to clear the clog with compressed air and a few ounces of mush blew out along with grayish brownish water, All drained out. Added some tap water and ran engine for 20 mins (165 F holding) and cleanish water came out, no sludge. Drained and added tap water and 2 bottles of Zerex super cleaner, ran for 2 hours (160 f holding), took sample from low petcock (pictured). Will run engine tomorrow for an hour and take another sample. I will probably drain, flush with distilled water & add Dexcool tomorrow. Yes I did notice a 5 F degree drop after adding Zerex super cleaner. - capt
