Corona Virus and Car Sales?
by Vern_in_IL - 02/26/20 07:34 PM
Emblem Adhesive Recommendation
by Fitz98 - 02/26/20 07:18 PM
Drain Plug Washer Frozen to Oil Pan
by CrackyWainwright - 02/26/20 06:31 PM
ams OE 0/20 6100 mi 14 KIA 2.4L GDI
by pair of Blazers - 02/26/20 06:17 PM
Any Exotic Brand Dealership Mechanics Here?
by john_pifer - 02/26/20 06:14 PM
Sentra no start
by Aredeeem - 02/26/20 06:07 PM
Sync Update 2016 Cmax
by borgward - 02/26/20 03:30 PM
Kirkland 0w20 at local Costco
by paulri - 02/26/20 03:12 PM
LG Red in a VW DSG trans?
by racin4ds - 02/26/20 02:31 PM
2013 Jaguar XF 3.0 AWD
by ET16 - 02/26/20 02:25 PM
Ford....in trouble??
by earthbound - 02/26/20 01:31 PM
Interesting read
by double vanos - 02/26/20 10:51 AM
2010 Honda Element 127K miles valvetrain picture
by SLO_Town - 02/26/20 10:01 AM
Anyone Used a Sea Sucker Bike Rack/Mount?
by jcartwright99 - 02/26/20 09:46 AM
8 passenger vehicle typically 5 for <=$15k
by madRiver - 02/26/20 09:27 AM
RON Octane Gasoline rating
by Building3 - 02/26/20 09:26 AM
Who makes Canadian Supertech?
by Patman - 02/26/20 09:08 AM
Scotts994Runner, Bu33leGutz, splitthebreak, shadango, JimNastic316
70808 Registered Users
110 registered members (2002 Maxima SE, AC1DD, 2003f7, 4WD, 2004tdigls, 14Accent, 12 invisible), 2,083 guests, and 20 spiders.
Topics301,961
Posts5,206,403
Members70,808
Injector sleeves in 7.3 Powerstroke w/ 6 sp MT #5165912 07/19/19 10:32 PM
E
Earls1st Offline OP
E
Fuel over-filling the coolant tank and present in engine oil. Approx 125000 miles on the motor. Does this require head removal to diagnose? Are injector sleeves and fuel cups both terms for the same thing? Can the old sleeves be removed and replaced without removing the heads? Is there some maintenance I missed to cause this problem? Does driving style cause this problem? Can fuel additives either prevent or hasten the development of this problem?
Re: Injector sleeves in 7.3 Powerstroke w/ 6 sp MT [Re: Earls1st] #5165940 07/19/19 11:36 PM
clinebarger Offline
It just happens, They are made of Brass & can crack. I've always called them Injector Cups.....
My removal/installation tools are OTC & makes the job possible without removing the cylinder heads, Probably some cheaper tools available! Use OE Ford Cups & Injector seal kits!!!!!!
If the fuel is left in the cooling system long enough......It ruins EVERYTHING that's made of rubber along with anything with a rubber seal.
Radiator
Heater core
All coolant hoses
Water pump
Radiator cap
Most just replace the offending cup.....I highly recommend replacing all 8!!
2001 Chevy Camaro L92/4L80E
Re: Injector sleeves in 7.3 Powerstroke w/ 6 sp MT [Re: clinebarger] #5166037 07/20/19 06:20 AM
M
mattd Offline
M
Yes it can be done heads on engine but it’s not the easiest. Do all 8. You’ll need a remover and installer and some specialty green loctite. As far as something you could have done to prevent this, not really no. They just crack over time. I would drive the truck like this at all if it’s overfilling the coolant explanation tank. As Cline said, you’ll need replace everything rubber in the cooling system, flush the radiator and heater core at minimum and replace the water pump.
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: Injector sleeves in 7.3 Powerstroke w/ 6 sp MT [Re: Earls1st] #5166468 07/20/19 03:41 PM
bdcardinal Offline
Fairly common, we do them occasionally. Not as much as when I first started in 2007, but still do them. You will need the remover/installer as well as the correct green Locitie. Fortunately the parts aren't expensive.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Injector sleeves in 7.3 Powerstroke w/ 6 sp MT [Re: Earls1st] #5166588 07/20/19 05:53 PM
M
mattd Offline
M
My post was meant to say NOT drive the truck . Sorry phone sucks
ASE Master, L1, L2
