Corona Virus and Car Sales?
by Vern_in_IL - 02/26/20 07:34 PM
Emblem Adhesive Recommendation
by Fitz98 - 02/26/20 07:18 PM
Drain Plug Washer Frozen to Oil Pan
by CrackyWainwright - 02/26/20 06:31 PM
ams OE 0/20 6100 mi 14 KIA 2.4L GDI
by pair of Blazers - 02/26/20 06:17 PM
Any Exotic Brand Dealership Mechanics Here?
by john_pifer - 02/26/20 06:14 PM
Sentra no start
by Aredeeem - 02/26/20 06:07 PM
Sync Update 2016 Cmax
by borgward - 02/26/20 03:30 PM
Kirkland 0w20 at local Costco
by paulri - 02/26/20 03:12 PM
LG Red in a VW DSG trans?
by racin4ds - 02/26/20 02:31 PM
2013 Jaguar XF 3.0 AWD
by ET16 - 02/26/20 02:25 PM
Ford....in trouble??
by earthbound - 02/26/20 01:31 PM
Interesting read
by double vanos - 02/26/20 10:51 AM
2010 Honda Element 127K miles valvetrain picture
by SLO_Town - 02/26/20 10:01 AM
Anyone Used a Sea Sucker Bike Rack/Mount?
by jcartwright99 - 02/26/20 09:46 AM
8 passenger vehicle typically 5 for <=$15k
by madRiver - 02/26/20 09:27 AM
RON Octane Gasoline rating
by Building3 - 02/26/20 09:26 AM
Who makes Canadian Supertech?
by Patman - 02/26/20 09:08 AM
Scotts994Runner, Bu33leGutz, splitthebreak, shadango, JimNastic316
70808 Registered Users
110 registered members (2002 Maxima SE, 928, 2003f7, 4WD, 2004tdigls, 14Accent, 12 invisible), 2,095 guests, and 20 spiders.
Topics301,961
Posts5,206,403
Members70,808
Which 0W20 to slow use #5165898 07/19/19 10:09 PM
L
lukejo Offline OP
L
2012 Camry. 199,000 miles. All highway driving. Having to add 1 quart every 1,500 miles. No leaks. Have tried both PP and M1 in EP and AP, and usage was the same.
If I want to stay in grade, do you think any other brands would do any better?
Re: Which 0W20 to slow use [Re: lukejo] #5165904 07/19/19 10:17 PM
B
burla Offline
B
200k miles, consider going out of grade or shop low noack oils.
Re: Which 0W20 to slow use [Re: lukejo] #5165924 07/19/19 10:49 PM
J
JEL01 Offline
J
When my Honda was using almost that much 5w20 I bumped up to 5w30 HM (various brands) and all substantially reduced burning with no fuel economy hit
Cars I maintain:
02 Mercedes CLK430
09 Honda Accord V6
13 Lexus RX350 AWD
02 Toyota Tundra 4x4
18 Lexus GX460
Re: Which 0W20 to slow use [Re: lukejo] #5165929 07/19/19 11:03 PM
T
tiger862 Offline
T
Try Havoline high mileage or Valvoline Advanced High Mileage 0w20. Both would be in grade with Valvoline Advanced with Maxlife would get nod.
Tiger862
2018 Grand Caravan
Re: Which 0W20 to slow use [Re: lukejo] #5165938 07/19/19 11:35 PM
SR5 Offline
A 7 year old Camry with almost 200k miles. Easy !!
5W30 In winter and 10W30 in summer.
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: Which 0W20 to slow use [Re: lukejo] #5165969 07/20/19 01:32 AM
Dylan1303 Offline
PPHM 0w20
12 cruze rs 1.4t 6spd pp 5w30 tuned on 22psi
19 cruze auto 1.4t amsoil oe 5w20 tuned on 24psi
Re: Which 0W20 to slow use [Re: lukejo] #5165971 07/20/19 01:40 AM
SR5 Offline
BTW the Australian spec for the Toyota Camry with the 2.5 Litre 2AR-FE VVT-I is 0W20, 5W30, 10W30 or 15W40 take your pick.
Is that the engine you have ?
Re: Which 0W20 to slow use [Re: lukejo] #5165980 07/20/19 02:35 AM
N
Nederlander75 Offline
N
0w20 is the Devil.
Re: Which 0W20 to slow use [Re: lukejo] #5165983 07/20/19 03:21 AM
demarpaint Offline
I'd bump up a grade as others suggested.
God Bless Our Troops
Re: Which 0W20 to slow use [Re: lukejo] #5165999 07/20/19 04:37 AM
R
Rolla07 Offline
R
Use a HM oil.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: Which 0W20 to slow use [Re: lukejo] #5166008 07/20/19 05:01 AM
T
Tjbouwhu Offline
T
I have always been reluctant to move too far from OEM oil recommendations. From Amsoil web site:
https://blog.amsoil.com/what-happens-if-i-use-the-wrong-weight-viscosity-of-oil/
Yet, as was pointed out earlier, auto manufacturers seem to have different oil recommendations for the same engine in different countries???
I don’t understand...
Tom
Re: Which 0W20 to slow use [Re: SR5] #5166038 07/20/19 06:21 AM
53' Stude Offline
I believe his is the 2AZ-FE same as in my 2009 Camry
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: Which 0W20 to slow use [Re: lukejo] #5166045 07/20/19 06:27 AM
H
HowAboutThis Offline
H
I'd make sure I knew why it was losing oil. A lot of miles? PCV valve? Leaking filter? Some variable valve timing thingy seal like my Honda used to enjoy leaking from? Etc.
If it's just a lot of miles, heavier grade as some said might help. Or HM oil. Otherwise, a quart every 1500 isn't bad for 200k.
If it's from something leaking and not just a wearing engine, then fix that and keep using 0w20.
Re: Which 0W20 to slow use [Re: lukejo] #5166060 07/20/19 06:45 AM
P
PowerSurge Offline
P
Try Toyota Synthetic oil. I know it’s made by Mobil, but it seems to not burn off at the same rate as Mobil 1. I have an old Honda I use as a daily beater and I never have to add oil between changes and it has over 220,000 miles. My dealer (4.25 quart) sells it a lot cheaper than Amazon.
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra and a few others
Re: Which 0W20 to slow use [Re: lukejo] #5166126 07/20/19 07:59 AM
danez_yoda Offline
Does it smoke when you start or while running?
Do you see oil drips on the ground?
Have you changed your PCV ever? That could cause oil consumption as well.
If none of these things apply put some 5W30 in for one OCI or 5K miles and see if the consumption goes down. Maybe a 0W-30 but it is harder to find.
