Originally Posted by Rand
your tank most likely has a hole or tear in the pressure bladder.
Another way to tell is turn off the well pump.. run the tub or some other heavy water use(hose to drain is ok too).. if you hear air start shooting out in your lines you definitely have a bad tank.
you can use it with a bad tank for months but gradually the water will absorb air out of the tank and become waterlogged again.
to properly air it up you need to drain the tank fully.. which might require you to add air(due to bad tank) once you hear air coming out in the line shut off the water at the tank
If you have normal continuous system pressure of around 40psi I would think around 25-30psi in the tank would be decent as the air fills the whole tank and not just the bladder/membrane side.
this should keep it going ok for a few months until you replace the tank which is usually a very easy job but sometimes it can be difficult due to how its installed.
For example my last replacement the brass tee had a sweated on fitting (soldered) on one side and plastic on the other
I ended up cutting the brass tee and unscrewing from the soldered fitting on the pipe.. then spinning on a new 2pc brass tee.. etc. but its usually not that hard.
you should be fine with the 20gal pressure tank for around $140 you might be fine with a smaller one usually constant pressure use a small tank but you can retrofit them into a system with a larger tank and have 0 issues as well.
I'm not even close to an expert but I've done quite a few of these.
Wow thanks for the info. Can you tell me if this is a sweated on Tee? The shutoff valve to the house I see tape, but I can't clean off that goop.
The one way valve well side.
