Corona Virus and Car Sales?
by Vern_in_IL - 02/26/20 07:34 PM
Emblem Adhesive Recommendation
by Fitz98 - 02/26/20 07:18 PM
Drain Plug Washer Frozen to Oil Pan
by CrackyWainwright - 02/26/20 06:31 PM
ams OE 0/20 6100 mi 14 KIA 2.4L GDI
by pair of Blazers - 02/26/20 06:17 PM
Any Exotic Brand Dealership Mechanics Here?
by john_pifer - 02/26/20 06:14 PM
Sentra no start
by Aredeeem - 02/26/20 06:07 PM
Sync Update 2016 Cmax
by borgward - 02/26/20 03:30 PM
Kirkland 0w20 at local Costco
by paulri - 02/26/20 03:12 PM
LG Red in a VW DSG trans?
by racin4ds - 02/26/20 02:31 PM
2013 Jaguar XF 3.0 AWD
by ET16 - 02/26/20 02:25 PM
Ford....in trouble??
by earthbound - 02/26/20 01:31 PM
Interesting read
by double vanos - 02/26/20 10:51 AM
2010 Honda Element 127K miles valvetrain picture
by SLO_Town - 02/26/20 10:01 AM
Anyone Used a Sea Sucker Bike Rack/Mount?
by jcartwright99 - 02/26/20 09:46 AM
8 passenger vehicle typically 5 for <=$15k
by madRiver - 02/26/20 09:27 AM
RON Octane Gasoline rating
by Building3 - 02/26/20 09:26 AM
Who makes Canadian Supertech?
by Patman - 02/26/20 09:08 AM
Scotts994Runner, Bu33leGutz, splitthebreak, shadango, JimNastic316
70808 Registered Users
139 registered members (55hambone, 2003f7, 5AcresAndAFool, 4WD, Aichiguy, AC1DD, 14 invisible), 1,997 guests, and 15 spiders.
Topics301,961
Posts5,206,437
Members70,808
Royal Purple Filter Mileage Rating #5165857 07/19/19 08:53 PM
J
JerryBob Offline OP
J
I can't find much info online about how long you can run a RP filter. Anyone have an opinion or knowledge on whether they can go as long as a Fram or Mobil-1, mileage-wise?
I know they're great filters, but if the amount of media is on the small side, I suppose the mileage could be on the small side.
Re: Royal Purple Filter Mileage Rating [Re: JerryBob] #5165869 07/19/19 09:05 PM
4WD Online Confused
Online Confused
I’m using the RP 20-500 which is mid sized like and XG10575, FL500 s, or PF63
Re: Royal Purple Filter Mileage Rating [Re: JerryBob] #5165963 07/20/19 12:59 AM
L
Linctex Offline
L
It's the same exact filter as Amsoil and Donaldson when cut apart and compared side-by-side.
I've ran a plain Motorcraft FL-1A to 30,000 miles back in the middle 1990's (with regular oil changes) and had no failures (filter looked great).
Today's engines run even cleaner yet.
Re: Royal Purple Filter Mileage Rating [Re: Linctex] #5166512 07/20/19 04:29 PM
G
Garak Offline
G
I've mentioned it before, but I remember back in mid 1980s, the FL-1A was advertised as the long life alternative to the originally specified CFL-1. wink
Plain, simple Garak.
Re: Royal Purple Filter Mileage Rating [Re: 4WD] #5221665 09/24/19 07:02 PM
4WD Online Confused
Online Confused
This filter came off today at 10k … I had planned to run a bit longer, but oil pressure was at 60 psi this am (40 is norm) for the first few miles while the engine warmed. It was 80F outside … and the oil is 0w20.
Put on a PF63E … will go another 2k or so on this OCI.
Somebody asked if these had baseplate PRV … but it’s dome end and looks similar to Wix XP design
99E51923-72DD-4E39-B973-C043FF64B041.jpeg5ABAA0E2-64F0-49C6-B526-C961A83E705E.jpegF48E6A7E-F9E1-44A5-8E33-3D82CB75FE3D.jpeg
Re: Royal Purple Filter Mileage Rating [Re: JerryBob] #5222037 09/25/19 08:18 AM
F
Farnsworth Offline
F
Miles until clogged filter varies from car to car, where and how it's used and the condition. They should put grams of standard test dust on the box. You still have to inspect the inside of a filter to see if it looks clogged or not according to your liking. Mileage on box doesn't mean much if anything.
Re: Royal Purple Filter Mileage Rating [Re: JerryBob] #5222840 09/26/19 07:43 AM
H
Hannibal Offline
H
I've personally went 20k on a Royal Purple (10-2867) before and it looked every bit as good as what 4WD posted. I would never hesitate to run an RP out further than a M1, etc.
Re: Royal Purple Filter Mileage Rating [Re: Farnsworth] #5222896 09/26/19 09:04 AM
4WD Online Confused
Online Confused
One thing that went through my mind was the additional pressure was exactly what the PRV setting is.
I don’t know what else could cause that spike ... so cheap and easy to just change the filter.
Next cold start was normal
Re: Royal Purple Filter Mileage Rating [Re: 4WD] #5223299 09/26/19 05:01 PM
Z
ZeeOSix Offline
Z
What vehicle was it on? Only way for a clogged oil filter to show increased oil pressure is if the pressure sensor is located before the filter.
Re: Royal Purple Filter Mileage Rating [Re: ZeeOSix] #5223305 09/26/19 05:07 PM
4WD Online Confused
Online Confused
Yeah I know that but don’t know where the sensors are ... it’s a variable pump system on L83
20 psi on an 80 degree day and 0w20 is very strange to me
Acting normal now
Re: Royal Purple Filter Mileage Rating [Re: 4WD] #5223354 09/26/19 06:09 PM
4WD Online Confused
Online Confused
The two stage pump test should only reach 60 psi above 3700 rpm … I saw 60 psi at idle which the engine has never done … Regardless … I got 10k from that filter and only bought it while wading through all the ecore bashing here … I’m good running PF63E now and have a couple Baldwin in the stash
Eventually I will go back to XP
Re: Royal Purple Filter Mileage Rating [Re: JerryBob] #5223431 09/26/19 07:47 PM
Z
ZeeOSix Offline
Z
^^^ Yeah, computer controlled variable output PD oil pump ... who knows what kind of weirdness they can exhibit. grin2
Re: Royal Purple Filter Mileage Rating [Re: ZeeOSix] #5223435 09/26/19 07:51 PM
4WD Online Confused
Online Confused
I tried to get a look … tucked away
Here is a picture off the internet
