Drain Plug Washer Frozen to Oil Pan
by CrackyWainwright - 02/26/20 06:31 PM
ams OE 0/20 6100 mi 14 KIA 2.4L GDI
by pair of Blazers - 02/26/20 06:17 PM
Any Exotic Brand Dealership Mechanics Here?
by john_pifer - 02/26/20 06:14 PM
Sentra no start
by Aredeeem - 02/26/20 06:07 PM
Sync Update 2016 Cmax
by borgward - 02/26/20 03:30 PM
Kirkland 0w20 at local Costco
by paulri - 02/26/20 03:12 PM
LG Red in a VW DSG trans?
by racin4ds - 02/26/20 02:31 PM
2013 Jaguar XF 3.0 AWD
by ET16 - 02/26/20 02:25 PM
Ford....in trouble??
by earthbound - 02/26/20 01:31 PM
Interesting read
by double vanos - 02/26/20 10:51 AM
2010 Honda Element 127K miles valvetrain picture
by SLO_Town - 02/26/20 10:01 AM
Anyone Used a Sea Sucker Bike Rack/Mount?
by jcartwright99 - 02/26/20 09:46 AM
8 passenger vehicle typically 5 for <=$15k
by madRiver - 02/26/20 09:27 AM
RON Octane Gasoline rating
by Building3 - 02/26/20 09:26 AM
Who makes Canadian Supertech?
by Patman - 02/26/20 09:08 AM
Benefits of a hard break-in discussion
by buster - 02/26/20 08:54 AM
2004 Cavalier 2.2L Oil Change Interval?
by Bob5150 - 02/26/20 08:44 AM
Scotts994Runner, Bu33leGutz, splitthebreak, shadango, JimNastic316
70808 Registered Users
100 registered members (4WD, benjy, 14Accent, BAJA_05, Beria, A_User55555, 11 invisible), 2,091 guests, and 17 spiders.
Topics301,959
Posts5,206,363
Members70,808
Yanmar marine 6lya-stp Needs Flush (or more)!! #5165853 07/19/19 08:48 PM
Capt Online Content OP
OP Online Content
I am dealing with a customer boat 2007 Yanmar 6lya-stp 370hp with a neglected cooling system. I tried to drain coolant from block petcock and not a drop.. after inserting 6'' screw drivers into hole came nothing but brown hard sludge... not a drop of liquid! Upper coolant reservoir & heat exchanger top showed rusty brown water, not pretty.
It should be flushed several times to operating Temp & filed with a O.A.T. ELC or Dexcool per Yanmar specs.
What would be a good product to remove sludge buildup???
This engine ran 30 hrs at 80% (2800 rpm) power 400 miles just a few months ago @ 170F with no issues, but I think its a ticking time bomb...
any suggestions?
Thanks,
Capt
Re: Yanmar marine 6lya-stp Needs Flush (or more)!! [Re: Capt] #5165866 07/19/19 09:03 PM
R
Rand Online Content
Online Content
R
non marine engines I'd use prestone super flush or citric acid.
but I dont work on closed system marine engines...
Re: Yanmar marine 6lya-stp Needs Flush (or more)!! [Re: Capt] #5165883 07/19/19 09:35 PM
M
mattwithcats Offline
M
Go by a hardware store, pick up a box of Tri Sodium Phosphate, TSP...
Add 1/2 to 1 tablespoon per gallon of system capacity...
Also consider installing a coolant filter if possible...
https://en.m.wikipedia.org/wiki/Trisodium_phosphate
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Yanmar marine 6lya-stp Needs Flush (or more)!! [Re: Capt] #5165960 07/20/19 12:57 AM
L
Linctex Offline
L
White vinegar and citric acid are mentioned al the time.
Cascade automatic dishwasher soap also cleans well.
A closed loop system marine engine shouldn't be too much different than a car/truck.
Does the big Yanmar use dry sleeves or wet sleeves?
Re: Yanmar marine 6lya-stp Needs Flush (or more)!! [Re: Capt] #5166115 07/20/19 07:47 AM
B
bullwinkle Online Confused
Online Confused
B
I'm guessing something bad has happened-major cooling system leak through the heat exchangers-or worse?
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Yanmar marine 6lya-stp Needs Flush (or more)!! [Re: Capt] #5166308 07/20/19 11:13 AM
OP Online Content
Not Sure about the sleeves. I believe the issue is from old coolant or possibly mixing of incompatible coolants as I noticed a jug on the boat with a missing label, who knows... We have not noticed any coolant loss or gain so hopefully the system is still intact, I will probably do a leak down test. I will start with an automotive radiator flush and report back. Thanks -capt
Re: Yanmar marine 6lya-stp Needs Flush (or more)!! [Re: Capt] #5167086 07/21/19 08:56 AM
R
roadrunner1 Offline
R
FleetGuard make a product, Restore/Restore+ for cleaning cooling systems. I've used it and it works very well.
'15 F350 6.7
Re: Yanmar marine 6lya-stp Needs Flush (or more)!! [Re: roadrunner1] #5168472 07/22/19 08:28 PM
OP Online Content
Hello all, I was able to clear the clog with compressed air and a few ounces of mush blew out along with grayish brownish water, All drained out. Added some tap water and ran engine for 20 mins (165 F holding) and cleanish water came out, no sludge. Drained and added tap water and 2 bottles of Zerex super cleaner, ran for 2 hours (160 f holding), took sample from low petcock (pictured). Will run engine tomorrow for an hour and take another sample. I will probably drain, flush with distilled water & add Dexcool tomorrow. Yes I did notice a 5 F degree drop after adding Zerex super cleaner. - capt
