Turtle Wax Ice Spray Wax use tips.
by JimPghPA - 05/25/20 08:53 PM
Best oil on the market?
by sloinker - 05/25/20 08:47 PM
Xfinity Race in Charlotte
by kstanf150 - 05/25/20 08:12 PM
Purolator PBL14610 C&P
by FordBroncoVWJeta - 05/25/20 08:00 PM
Carquest Blue 85522 C&P
by FordBroncoVWJeta - 05/25/20 07:52 PM
2020 RAV4 Hybrid - oil options
by CELICA_XX - 05/25/20 07:44 PM
any battery charger/repair that can fix sulfation?
by apollo18 - 05/25/20 07:28 PM
Need Mice Advice
by Mr_Luke - 05/25/20 07:01 PM
pressure washer air compressor oil
by bedwards - 05/25/20 06:49 PM
2014 Elantra delayed shift 4th to 5th
by Propflux01 - 05/25/20 05:51 PM
2002 Ranger Electrical Weirdness (GEM, RAP?)
by DuckRyder - 05/25/20 05:47 PM
Oil change problems
by philipp10 - 05/25/20 05:41 PM
Denso 150 3024
by thrace - 05/25/20 04:58 PM
does ac delco warranty the replacement battery?
by apollo18 - 05/25/20 04:39 PM
Water drainage issue
by Paul_Siu - 05/25/20 04:39 PM
13 Corolla PCV
by AJB0009 - 05/25/20 04:24 PM
SpaceX Launch - Wednesday
by MasterSolenoid - 05/25/20 04:15 PM
Atf for my E4od
by R1jake - 05/25/20 04:04 PM
mikespine, Typerguy, showtyme1958, rickyradit, YogiTheCat
71528 Registered Users
94 registered members (bbhero, antonmnster, 3turbodiesels, bcossa2001, 97prizm, apollo18, 8 invisible), 2,212 guests, and 42 spiders.
Topics305,877
Posts5,281,900
Members71,528
Evonik Viscoplex Calculators - Present for Gokhan #5081145 04/20/19 08:17 PM
Shannow Offline OP
Trying to re-gather lost files after computer failure (too long between back-ups, not enough that it really hurts), and found some great data sheets from Evonik...went looking for the source data, and any updates, and they have this...
https://oil-additives.evonik.com/product/oil-additives/resources/blending-efficiency-en.html
A blending calculator, where you can put the base oil viscosity in, pick a target KV100, and it spits out how much Viscosity Modifier to use...or back the other way...
[Linked Image]
If it's the truth....it can handle the pressure !!!
Re: Evonik Viscoplex Calculators - Present for Gokhan [Re: Shannow] #5081168 04/20/19 08:40 PM
gathermewool Offline
Is that percentage compared to the entire add pack?
It can’t be compared to the base oil...can it?
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (2nd OFI) (77,760mi, 3/7/20)
15 Legacy Premium FB25
Magnatec 0W-20 D1G2+ FU filter (2nd OFI) (54,621mi, 3/4/20)
Re: Evonik Viscoplex Calculators - Present for Gokhan [Re: Shannow] #5081170 04/20/19 08:42 PM
Shannow Offline OP
It's just base oil and VII
Re: Evonik Viscoplex Calculators - Present for Gokhan [Re: Shannow] #5081191 04/20/19 09:17 PM
Shannow Offline OP
So when messing with (say) the mobil blend guide, it's the percentage of the base oil component not the entire bottle contents.
Re: Evonik Viscoplex Calculators - Present for Gokhan [Re: Shannow] #5081511 04/21/19 09:18 AM
That's still a lot. I never realized!
Re: Evonik Viscoplex Calculators - Present for Gokhan [Re: Shannow] #5165715 07/19/19 07:15 PM
G
Gokhan Offline
G
I just saw this, thanks!
The amount of raw (solid) VII (VM) polymers used in oils are only about 1 - 2% for all VII types except the polymethacrylate (PMA) VII, which is 5 - 6%.
The rest of the VII sold commercially is a solvent (such as Group I base oil) used to dissolve the solid VII polymers so that it can be readily dissolved in the finished oil. In theory you can also dissolve the solid polymer in the finished oil but in practice that could give the blenders a huge headache and it's much easier to buy already-oil-dissolved polymers instead.
Yes, as your plot indicates, the relation between the VII content and viscosity is fairly linear, which is what I assume in my calculations.
The recent pair of papers by Hugh Spikes et al. discussed in this thread studies VIIs in full glory, with the Part II focused on fuel economy:
https://www.bobistheoilguy.com/foru...y-hthsv-friction-and-wear-state-of-the-a
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 65 mpg on regular gasoline, ~ 5,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
