Changed the spark plugs on Subaru BRZ with pics
by Ded Mazai - 04/04/20 01:08 PM
Two filter sizes for Skyactiv 2.5?
by buster - 04/04/20 12:31 PM
Valvoline AFS Euro 0W-40 $25-4-10 Qts.
by Jackson_Slugger - 04/04/20 11:36 AM
pay cut at work
by marine65 - 04/04/20 11:17 AM
Asking For Advice- Lubricate Under Hot Water
by PGB1 - 04/04/20 11:05 AM
Castrol Magnatec 0W-20 2-4-$30
by Jackson_Slugger - 04/04/20 10:58 AM
Purolator One synthetic vs paper
by Duffyjr - 04/04/20 10:57 AM
RockAuto Discount Code
by RoadDukie - 04/04/20 10:53 AM
Grease fittings on drop links - is this a defect?
by wolfestone - 04/04/20 10:51 AM
How clean vinyl steering wheel?
by WobblyElvis - 04/04/20 10:49 AM
90s European Toyotas Coolant
by EWPE - 04/04/20 10:42 AM
Locker plants are swamped
by P10crew - 04/04/20 10:39 AM
New Jeep Rear Cargo Tray
by 2015_PSD - 04/04/20 10:30 AM
I'm getting fat.
by BeerCan - 04/04/20 10:26 AM
Penne alla Boscaiola
by vavavroom - 04/04/20 10:05 AM
Fuel stabilizers for e10 gas - long storage
by caprice_2nv - 04/04/20 09:59 AM
More home made junk
by P10crew - 04/04/20 08:11 AM
Battery for Crosstrek
by Donald - 04/04/20 07:41 AM
0W0 Ceramic synthic oil
by David1 - 04/04/20 04:17 AM
357sig, Garyv, PGB1, YoDaveO, Johnya25
71094 Registered Users
93 registered members (2009Edge, Bottom_Feeder, BHopkins, blufeb95, 2015_PSD, Bighorn2500, 5 invisible), 2,493 guests, and 23 spiders.
Topics303,586
Posts5,237,809
Members71,094
Mobil One design change M1C-154A #5163661 07/17/19 05:26 PM
P
piesled Offline OP
P
I recently purchased 2 mobil one filters for my corolla. Upon pick-up I noticed immediately that the boxes were different sizes. I opened them and the filters were different. Not sure which one is older, but I have been using these filters for about 7 years and they have always looked like the blue top filter. Just thought I would share and have included pics. The all paper top looks like it is slightly larger and may even be better at filtration.
Re: Mobil One design change M1C-154A [Re: piesled] #5163763 07/17/19 07:42 PM
slacktide_bitog Offline
Still Chinese mad
Maybe not bad if they're from the Walmart clearance bin for $3
Otherwise, get Mahle
Re: Mobil One design change M1C-154A [Re: slacktide_bitog] #5163907 07/17/19 10:56 PM
drtyler Offline
Why is the Mahle filter better?
Originally Posted by slacktide_bitog
Still Chinese mad
Re: Mobil One design change M1C-154A [Re: piesled] #5163949 07/18/19 12:38 AM
F
FlyNavyP3 Offline
F
Fiber end cap filter looks IDENTICAL to the Fram Tough Guard cartridges that are also made in China. The M1 cartridge I put in a 2018 GS350 Lexus last week was metal end cap with sealing o-rings glued on the ends.
Luke
Re: Mobil One design change M1C-154A [Re: piesled] #5164014 07/18/19 05:59 AM
Sayjac Offline
There should be a date code somewhere on the cartridge. However, since the second with felt type endcaps different than previous that likely newer design. The endcap looks very similar if not identical to the Hyun/Kia oem cartridge endcap that was made by Mahle, Fram CH10855 same cartridge. In that case it's only one end cap because other end composite type needed for installation purposes. Anyway, wouldn't be concerned about using the cartridge based solely on felt/fiber type endcap.
As for coo, as opposed to the spin on type, many cartridges from US based filter companies are made in China. Just the way it is and in my observation doesn't make them substandard.
Re: Mobil One design change M1C-154A [Re: piesled] #5164123 07/18/19 08:43 AM
Hootbro Offline
I would have no issue using either filter. Champion Labs is the contract OE for the Mobil 1 filters and they are usually pretty good about making sure the quality is there even for their sub-contracted lines regardless of COO.
Unless you buy dealer OEM cartridge filters, it is hard to find them aftermarket and not be from China or Korea nowadays.
2020 Jeep Gladiator Rubicon 3.6L (Dealer Bulk 0W-20)
2018 Chevrolet Colorado Z71 3.6L (Dealer Bulk 5W-30)
2013 Volkswagen Jetta 2.5L (Havoline HM 5W-30)
Re: Mobil One design change M1C-154A [Re: Hootbro] #5164595 07/18/19 07:11 PM
The Mahle cartridge is made in Austria smile
Re: Mobil One design change M1C-154A [Re: slacktide_bitog] #5164909 07/19/19 05:58 AM
Sayjac Offline
Quote
...The Mahle cartridge is made in Austria..
The previously noted Mahle made OEM cartridge for Hyun/Kia (also Fram CH 10855) is made in S Korea.
Re: Mobil One design change M1C-154A [Re: Sayjac] #5165669 07/19/19 06:31 PM
Originally Posted by Sayjac
Quote
I was talking about the one they make for the OP's Corolla smile
Re: Mobil One design change M1C-154A [Re: slacktide_bitog] #5165995 07/20/19 05:21 AM
Sayjac Offline
Quote
And I was following up with coo on the mentioned Mahle made Hyun/Kia oem cartridge with similar endcap type to OPs second cartridge. And showing that Hootbro observation also correct about many cartridges now made in China and S Korea, even Mahle. smile
