I have an 18 year old Hayward Pool Filter. (3/4 HP 110V ) Today, the motor made a metallic death screech, smoke came out of the front bearing, and the breaker tripped. Let it cool off, reset breaker, and restarted. It runs fine except very noisy, I assume the front bearing is trashed, as that is where the smoke was coming from.
Is it worth a bearing swap on an 18 year old motor? A new motor is $160 and is most likely " typical offshore quality " that will last 5 years or so. I have put new bearings in a hot tub motor when no replacement was available.
Thanks in advance for any advice
