Ahh yes, drag out the "hate" thing when all else fails.
Here, I'll play too. The oil does not meet dexos and they tell you why it does not. You said it did but it does not. I was correcting you.
I never said it was a "poor quality oil", this is yet more amplification and hyperbole which is common when this particular brand is discussed. I presented the facts as stated by the blender themselves and you inflate it to something else. The "zip it" part is the best, kind of like when people say "nuff said", right?
BTW I use Amsoil products, or at least one of them. I use their MTF oil in my ECHO. So let's zip the "hate" thing, OK?
Originally Posted by JLTD
Ahh yes, there's the old unreasoning hate, a partial reminder of just why I ignore your posts.
However, I'll play this time:
Gee, more detergents? You chose that for support of your platform? It's freely admitted by the manufacturer and is probably a quality which helps allow extended drains.
So you choose to pick one parameter that exceeds an arbitrary specification required by a manufacturer that had trouble with existing oils causing detonation in their turbo DI vehicles....to correct their lugging engines from further damage. One. Granted, GM's specs set a maximum for their requirements. So don't use it in a GM engine. Believe it or not, millions of vehicles ran, and indeed still run just fine on non dexos oils!
Show me proof that Amsoil is a poor quality oil, or that it failed to control LSPI, or some other evidence other than your opinion and I will be convinced. Otherwise, zip it.
