So I had to remove my Alpine headunit a while back because the CANBUS adapter was causing a parasitic drain- as well the replacement adapter. Thats OK. The factory headunit does everything I need it to... Almost. I scored a deal on the SSL LoPro8 compact powered subwoofer during Prime Day and looking to install it in my 2011 F150 withOUT sync. Ideally, I'l like to utilize its high level input and tap into the rear speaker line while retaining rear speaker function. Is that possible? Secondary question, is there a good CANBUS adapter which won't cause a parasitic drain in my application (without breaking the bank)?
