Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
Chaucha, UofA, Jeffrey78, Markovchain, o_s
70787 Registered Users
80 registered members (55hambone, 4WD, 53' Stude, Aero540T, aba4430, 2010Civic, 6 invisible), 1,715 guests, and 19 spiders.
Topics301,818
Posts5,203,279
Members70,787
Massive amounts of PEA got into my oil ??? #5165403 07/19/19 01:10 PM
J
j_mac Offline OP
J
I have a direct injection 2012 Hyundai Accent with 197,000 miles I bought new that is sensitive to carbon buildup on the piston crown and combustion chambers. I actually drilled tiny holes in the intake manifold just before the head so I can stick the straw of a can of CRC GDI Intake Valve Cleaner and spray it directly onto the back of the valves. I unplug the coil for the cylinder I'm spraying with the engine running so the highly concentrated PEA in the cleaner will not burn in the cylinder and will coat the combustion space as well as the back of the valves. I've done this procedure before and it has a notable effect that is reflected in the fuel economy to the tune of at least 5 mpg on the road. I have a monitor plugged into the OBDII port and I can see less or no ignition timing is being pulled out under load, whereas before the treatment I saw an average of 4-5 degrees being pulled out under WOT and high RPMs. At part throttle I'm not sure how much timing is being pulled because the variables are so great, but I know at some points it is as much as 15 degrees because I was seeing "negative" timing numbers or for example -2 deg. (or 2 degrees AFTER TDC !!!) under lighter loads.
My question is will PEA in the crankcase cause undue harm or wear to the internals?
I wait an hour after spraying down a cylinder so it can do its work on the carbon, but I'm sure some PEA is pooling on the edge of the piston and probably leaking down past the rings and into the crankcase.
Last year I did a couple of these treatments and drove the car for a couple of days and then changed the oil. All has seemed fine since.
But do you guys think I am doing damage from the PEA getting into the oil or no?
As an important side note, I have found that buildup on the back of the valves really isn't an issue with my car as it still has just as much horsepower today as it did when it was new, so the intake ports couldn't be too choked off, but the issue seems to be carbon clogging up the combustion space. I've heard the DI creates more soot in the exhaust than port injection and apparently it may too cause more carbon buildup on the pistons and combustion chambers.
Re: Massive amounts of PEA got into my oil ??? [Re: j_mac] #5165432 07/19/19 01:36 PM
A
ARCOgraphite Offline
A
Wow. That's going the distance.
When I used to do stuff like a de-carboning, Id plan an oil change the for next day or so.
Now I just floor the car a lot when its foggy or really Humid smile
Now, How do you KNOW you have massive amount s of PEA getting in the oil?
Or, are you just postulating.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Massive amounts of PEA got into my oil ??? [Re: ARCOgraphite] #5165456 07/19/19 01:49 PM
J
j_mac Offline OP
J
That's why I'm here to ask those smarter or more knowledgeable than me. Do you think CRC GDI IVC would be able to sneak past the rings and into the oil within the hour I let it sit. I would assume at least a cc would be sitting around the top ring during the hour soak. And lets remember the CRC IVC is an EXTREMELY concentrated PEA cleaner. Give me your thoughts.
What happens when PEA makes it into the crankcase?
Re: Massive amounts of PEA got into my oil ??? [Re: j_mac] #5165461 07/19/19 01:53 PM
K
Kjmack Offline
K
Just change oil , it's what I do after the crc .
Re: Massive amounts of PEA got into my oil ??? [Re: j_mac] #5165490 07/19/19 02:35 PM
Brian553 Offline
The PEA cannot act as anything in the crankcase, and I don't believe it can transform or react with anything in there.
Not sure if it has any adverse friction modifying effects nor cause any increase in acidity of the bulk.
The worst of things happening IMO is the removal or wash off of oil on the rings and cylinder walls, which is worth the trade-off.
Re: Massive amounts of PEA got into my oil ??? [Re: j_mac] #5165523 07/19/19 03:13 PM
MolaKule Offline
Global Moderator
Global Moderator
I'm a Student Pilot. Frightening, isn't it?
Re: Massive amounts of PEA got into my oil ??? [Re: j_mac] #5165542 07/19/19 03:34 PM
R
RayCJ Offline
R
Well, I pea'd in my cylinders of my 2018 Mazda3, 2.5L using the recommended technique on the can of CRC GDI cleaner then, did an oil change about a week later. I collected an oil sample and the UOA results are herein listed. -No problems as far as I can tell. The engine/vehicle is new and the UOA reflects it.
https://www.bobistheoilguy.com/foru...ilesyn-sxr-0w20-5-100mi-2018-mazda3-2-5l
Ray
Re: Massive amounts of PEA got into my oil ??? [Re: j_mac] #5165548 07/19/19 03:46 PM
G
grjr Offline
G
I have no information to add about your question but you say you have holes drilled into you intake manifold so you can spray the cleaner into the intake ports.... what do you do to seal the holes when you aren't cleaning the engine?
Re: Massive amounts of PEA got into my oil ??? [Re: grjr] #5165734 07/19/19 06:38 PM
demarpaint Offline
My thoughts exactly.
God Bless Our Troops
Re: Massive amounts of PEA got into my oil ??? [Re: j_mac] #5165787 07/19/19 07:21 PM
Marco620 Offline
I used the CRC GDI throttle cleaner in my Hyundai Accent. Worked great following the instructions as follows. That hour or so it sits will do its job. I doubt the Pea is going to hurt anything. I have used redline si-1 for years and it will sneak past the cylinder wall into the oil. If anything the Pea might help clean up grime in the oil pan. Remember that gumout multi has pea in it and can be admitted multiple ways including the crankcase. I wouldn't worry about it too much. Start it up and drive it for an hour.. Should burn off.
15' Civic 1.8 i-vtec 311,000 mi M1 0w30 & LG Biotech, BP CVT Fluid,GUMOUT W/ PEA
Doberman Whisperer!
E pluribus unum.
Re: Massive amounts of PEA got into my oil ??? [Re: grjr] #5165879 07/19/19 09:29 PM
M
Mad_Hatter Offline
M
Cigarette butts?..or bubble gum? Hubba Bubba's my personal favorite fwiw..😂
Re: Massive amounts of PEA got into my oil ??? [Re: j_mac] #5165882 07/19/19 09:35 PM
M
Mad_Hatter Offline
M
Do the cleaning before the oil change. It's more important you keep that carbon buildup in the cylinder and piston tops to a minimum.
Re: Massive amounts of PEA got into my oil ??? [Re: Mad_Hatter] #5165884 07/19/19 09:37 PM
spasm3 Online Happy
Online Happy
Golf tees.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Massive amounts of PEA got into my oil ??? [Re: spasm3] #5165944 07/20/19 12:01 AM
J
j_mac Offline OP
J
To seal the miniature holes I simply take a tube of black RTV and put it over the hole and squirt and lift at the same time leaving what looks like a small Hershey Kiss. The old ones I cut off to do another cleaning had been there for over a year and were sticking like gorilla snot. Its actually running on little squares of duct tape covering the holes at the moment because its going to get 1 or 2 more cleanings and then sealed with Permatex RTV Hershey Kisses.
Re: Massive amounts of PEA got into my oil ??? [Re: j_mac] #5166511 07/20/19 04:26 PM
J
j_mac Offline OP
J
MolaKule,
Thank you for your link. I remember you when I first joined BITOG and you've helped me many times over the years. But I have a question... Just how long have you been stirring that pot? I KNOW its been at least 10 years!
