Which 15W40 for an Onan generator?
by atikovi - 02/21/20 06:39 PM
Valvoline Advanced 5W40 MST
by BurntMusic - 02/21/20 06:04 PM
2014 F250, 6.7L 13,000 OCI Amsoil AME 15w40
by claluja - 02/21/20 05:43 PM
What Are These On My Caliper Pistons?
by Fitz98 - 02/21/20 05:37 PM
Gun carry insurance
by Colt - 02/21/20 05:25 PM
drywall crack. how do i fix it?
by WhyMe - 02/21/20 02:55 PM
Yokohama AVID Ascend GT
by Bottom_Feeder - 02/21/20 02:53 PM
Getting my Chevy 4.3 to 300k
by CharlotteB - 02/21/20 02:16 PM
Updated PDS for Valvoline ME
by buster - 02/21/20 01:56 PM
Havoline ProDS Full Synthetic
by Fordiesel69 - 02/21/20 01:32 PM
Correct oil for flat tappets
by Gokhan - 02/21/20 11:55 AM
Laser tachometer?
by Elkins45 - 02/21/20 11:13 AM
Best beginner press?
by MVFarms - 02/21/20 10:20 AM
Help me pick a generator size
by dlundblad - 02/21/20 09:56 AM
...musical 'flat-tappet' oils
by Mad_Max_Sam - 02/21/20 09:44 AM
KIA
by WyrTwister - 02/21/20 09:42 AM
Valvoline NextGen Conventional
by Char Baby - 02/21/20 07:20 AM
Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
onuryas, vidirola, CharlotteB, Grennx, coverage
70766 Registered Users
99 registered members (another Todd, andyd, Aero540T, apollo18, Astro_Guy, AC1DD, 11 invisible), 2,316 guests, and 16 spiders.
Topics301,755
Posts5,202,154
Members70,766
[pics] 2004 Corolla spark plug, piston tops #5165262 07/19/19 10:55 AM
Z
zorobabel Offline OP
Z
This past Monday I changed the spark plugs on the 2004 Corolla with 202259 miles.
The old plugs (NGK Laser Iridium) have been in use for 104559 miles. They came out easy from a hot engine, I installed them with copper antiseize probably at the specced 18ftlb.
New Denso Iridium TT plugs went back in, copper antiseize also used, but only 15ftlb this time.
I also performed a compression test, I went by what what I saw the dial go up highest, not by how it rested (not sure that's how it's properly done).
#1
1997 Maxima 210k, Castrol GTX Synblend 5W-30, PL14459
2004 Corolla 211k, Valvoline SynPower 5W-30, K&N HP-1003
#2 [Re: zorobabel] #5165263 07/19/19 10:56 AM
Z
Z
#2
#3 [Re: zorobabel] #5165264 07/19/19 10:57 AM
Z
Z
#3
#4 [Re: zorobabel] #5165267 07/19/19 10:58 AM
Z
Z
#4
Re: #4 [Re: zorobabel] #5165287 07/19/19 11:15 AM
P
Phishin Offline
P
A couple of questions:
In your signature, you have listed "VWB + SSS + Rislone cocktail" What's SSS? What does Rislone supposedly do?
The pics of your plugs looks "textbook" to photos you see in handbook of someone who runs a lot of additives. Do you run anything extra in your gas?
2018 Chevy Silverado 3500HD 6.0L Gas: RLI 10w30
2010 Accord-LX K24: MaxLife 5w30 + Torco MPZ
2014 CR-V LX K24: M1 0w30
Re: #4 [Re: Phishin] #5165342 07/19/19 12:06 PM
Z
Z
I had a mixture of 2.5qt VWB 5w-20 SM, 1qt Smity SuperS 5W30 SN, .075qt Smitty SuperS 10W-40 SN, plus some top ups with VWB 5W-30 SM. The Rislone in question is the Rislone 4102 which I used for the first time, it supposedly cleans sludge etc. (oil was as clear as ever on the dipstick, I'll see what the filter holds when I get around to cutting it). All this was drained on Tuesday.
As for gas additives, I used Techron maybe every 5k miles, maybe a few ounces of MMO a couple of times. This engine burns about 1qt every 5k miles.
Re: #4 [Re: zorobabel] #5165355 07/19/19 12:12 PM
H
hemitom Offline
H
Those plugs look pretty good for 100000 miles on them.
What brand of gas do you run ?
2009 Saturn Vue.
2015 Mustang GT Convertible.
Re: #4 [Re: hemitom] #5165361 07/19/19 12:20 PM
Z
Z
Mostly a local brand: G&M oil. When travelling, I stick to name brands or truck stop brands (Flying J, Love's)
Re: #4 [Re: zorobabel] #5165384 07/19/19 12:44 PM
N
NO2 Offline
N
Try using a top tier brand gas and skip the Tecron
Re: #4 [Re: zorobabel] #5165395 07/19/19 12:57 PM
B
BMWTurboDzl Offline
B
Wow. Talk about running lean. Look at all that white powder. How are your mpgs?
435i
Re: #4 [Re: BMWTurboDzl] #5165424 07/19/19 01:30 PM
Z
Z
MPG is down maybe 1-2 from many years ago. On a 500 mile trip last weekend it averaged 37.x MPG.
At the end of May I wanted to take this car on a long trip so I did a pre-trip check and found out it was running +12-14 LTFT at idle and +9 LTFT under load. As I was puling my hair out, at one point I unplugged the MAF with the engine running, just to see if it dies and it did. A couple of days later, with the MAF plugged back in and gas tank refilled LTFT dropped a lot to +4-5.5 idle and +7.8 loaded. It went about like that for a while and more recently it developed what I believe to be an intake leak (2 months ago, I tried an crapily improvised smoke machine and couldn't find any intake leak). This morning LTFT was +7.03 at idle, +4.69 at 2000 rpm.
Re: #4 [Re: zorobabel] #5165436 07/19/19 01:40 PM
L
LotI Offline
L
If you think you have an intake or vacuum leak you need to try propane.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX
Retired:
17 VW GTI
17 Mazda6 GT
14 Honda Accord Sport
Re: #4 [Re: zorobabel] #5165493 07/19/19 02:42 PM
K
krismoriah72 Offline
K
The white ash deposits are from burning oil.
Re: #4 [Re: zorobabel] #5165499 07/19/19 02:49 PM
camryrolla Offline
Stick with the Toyota preferred Denso Iridium over NGK Iridium plugs. No need to add any other additives to the oil or the gas, just a waste of money and just add white chalks to your plugs. Keep it simple by using top tier full-synthetic oils to keep your engine clean.
'11 Camry 2.5L 170K mi
'07 Corolla 1.8L 220K mi
Always Fram XG filter.
