Torque Specs for 2004 Dodge Ram transfer case
Southeast PA
Can someone please give me the torque specs for transfer case drain and fill plugs 2004 Dodge Ram 2500? (Transfer case NV271).
Snug.
TRANSFER CASE - NV271
TORQUE SPECIFICATIONS DESCRIPTION N-m Ft. Lbs. In. Lbs.
Plug, Detent 16-25 12-18 -
Plug, Drain/Fill 20-34 15-25 -
Bolt, Extension Housing 27-34 20-25 -
Bolt, Case Half 27-34 20-25 -
Nut, Range Lever 27-34 20-25 -
Sector Support 27-34 20-25 -
Nuts, Mounting 30-41 20-30 -
Position Sensor 20-34 15-25 -
Nut, Companion Flange 176-271 130-200 -
That is something that I only snug down. If you apply a lot of torque you might just get yourself into trouble. And as always with those ALWAYS take the fill plug out first.
