Sludge concerns
by otis24 - 04/09/20 08:43 AM
Anyone Ever Have Their OEM rims Powder Coated?
by LoneRanger - 04/09/20 07:59 AM
Group 7 V2222
by GumbyJarvis - 04/09/20 03:56 AM
I'm looking for a 0w30 A5 B5 oil
by Marco620 - 04/08/20 11:57 PM
Does anyone put heat shrink tubing over a connector plug?
by motor_oil_madman - 04/08/20 10:39 PM
Anyone ‘excited’ for API SP/GF-6?
by addyguy - 04/08/20 10:30 PM
O'Reilly online learning for .gov email addresses
by spackard - 04/08/20 10:26 PM
Welding Helmet Fogging Up
by George7941 - 04/08/20 09:54 PM
Detroit 4-53T 2009 Ford F350 Update.:)
by A310 - 04/08/20 09:48 PM
Thoughts on CAFE standards
by otis24 - 04/08/20 09:20 PM
PUP amazon 5w-20
by Koncrete_Cam - 04/08/20 08:54 PM
Duralube Trans Shudder Fixx question
by soulburner - 04/08/20 08:36 PM
Number of Spare Magazines You Consider Adequate?
by 2015_PSD - 04/08/20 08:24 PM
Troy Bilt TB6044XP string trimmer dies when hot
by 92saturnsl2 - 04/08/20 07:18 PM
JD Yanmar deisel engine
by yankees1 - 04/08/20 07:14 PM
PQIA Looks at Leading 0W-20's
by Jackson_Slugger - 04/08/20 07:03 PM
Marine oil in a passenger car engine
by Thunderbolt - 04/08/20 06:50 PM
BG SAE 5W-30 Full Synthetic Engine Oil
by JonnySaab - 04/08/20 06:42 PM
edot1, Tori, siroisma, i4ni, Monica
71133 Registered Users
107 registered members (Alfred_B, 53' Stude, 1978elcamino, 007, aquariuscsm, 379KITTY, 8 invisible), 2,061 guests, and 20 spiders.
Topics303,812
Posts5,242,318
Members71,133
Blending TCW3 in diesel #5163809 07/17/19 08:27 PM
3
32319 Offline OP
3
I'm not sure if this is the best forum to post this question but it seems OK.
I use off-road diesel in my old off-road engines. Tractor, mower, generator set. Until the most recent storage tank fill, my fuel guy has been able to deliver 500 ppm fuel to me. He's been unable to get more since my last delivery a few years ago. Now I have 15 ppm ULSD off-road fuel in my tank.
I always use 200:1 TCW3 in 15 ppm road fuel in my 6.5 TD truck but I mix in the oil when I fill at the pump.
I plan to use TCW3 in my new ULSD off-road fuel I have in my storage tank but I wonder if this oil goes into solution and remains in solution in a stationary tank without agitation. If I pour a gallon of TCW3 into 200 gallons of fuel, will I soon have one gallon of TCW3 laying in the bottom of the tank or will it blend and remain blended?
Thank you,
DW
Re: Blending TCW3 in diesel [Re: 32319] #5163908 07/17/19 10:58 PM
Chris142 Offline
I think it needs to be agitated to mix. Not much though. How big is the storage tank? Can you aerate it somehow with air?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Blending TCW3 in diesel [Re: 32319] #5164004 07/18/19 05:42 AM
varmint Offline
Use a clean 5 Gallon gas can, put in 1/2 gal of TCW3 and fill with diesel. Pour this into storage tank. Repeat with remaining TCW3.
You might want to do another 5 gal of diesel just to agitate or if you have an electric pump use nozzle in tank fill hole to agitate.
Army Vet. 68-71
2000 Chevrolet Silverado 1500 5.3
2003 Chevrolet Malibu 3.1
2017 GMC Terrain 3.6
GL4740 Kubota tractor
Re: Blending TCW3 in diesel [Re: varmint] #5164007 07/18/19 05:49 AM
varmint Offline
Forgot to add, when adding diesel to TCW3 in 5 gal can, put about 1 gal of diesel and shake can well before filling can with diesel.
Army Vet. 68-71
Re: Blending TCW3 in diesel [Re: 32319] #5164192 07/18/19 10:22 AM
U
Ursatdx Offline
U
I use about a Qt of 2 stroke oil with each 50 gals diesel.
A bit of Biobor, too.
She loves it.
Cat 3116.
"If there must be trouble, let it be in my day, that my child may have peace." --- Thomas Paine
Re: Blending TCW3 in diesel [Re: 32319] #5164208 07/18/19 10:55 AM
R
rideahorse Offline
R
Why don't test it with a glass jar. Put diesel in first and then put a cap full of the tc3 in it without agitating it and see if it goes to the bottom.
Re: Blending TCW3 in diesel [Re: varmint] #5164235 07/18/19 11:31 AM
O
Oldmoparguy1 Offline
O
What is the deal with the counter weights on the wheels?
A Randomly Selected Thought For The Day:
If Noah had used Zip, he could have used a smaller boat.
Re: Blending TCW3 in diesel [Re: Oldmoparguy1] #5164236 07/18/19 11:34 AM
U
Ursatdx Offline
U
Not weights.
They protect components for the CTIS / Central Tire Inflation System.
You can inflate/deflate tire pressure on the fly or anytime using the engine driven
air compressor.
Re: Blending TCW3 in diesel [Re: 32319] #5164462 07/18/19 03:58 PM
3
32319 Offline OP
3
Thanks. I have 200 gallons in a 275 gallon IBC (tote) with a manual Fill-Rite piston pump. Not sure how I could aerate or agitate the fuel.
I guess I'll have to do it the hard way and do a 200:1 mix & separation test in a pickle jar and leave it sit to know if the oil comes out of solution. I'll probably end up having to mix in five gallon jugs and use it from there.
Re: Blending TCW3 in diesel [Re: 32319] #5164502 07/18/19 05:03 PM
H
hatt Offline
H
Totes have a large opening on top. You can use many things to mix its contents. Drill powered paddle mixer, boat oar, etc.
I use a couple to catch rainwater. I don't think I'd use them for long term fuel storage. The valve on the bottom looks pretty fragile. I'd worry about age.
2013 F150 5.0, Delo 400 XSP 5W-40, Wix 57502
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Blending TCW3 in diesel [Re: 32319] #5165172 07/19/19 10:17 AM
3
32319 Offline OP
3
My main concern is the oil falling out of solution over time.
No concern at all about keeping fuel in a tote. I've been doing that since 2004.
Re: Blending TCW3 in diesel [Re: 32319] #5165179 07/19/19 10:21 AM
K
kschachn Online Content
Online Content
K
I can't imagine that happening with two hydrocarbons.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Blending TCW3 in diesel [Re: kschachn] #5167379 07/21/19 03:19 PM
3
32319 Offline OP
3
Simple logic tells me the same thing. It would be nice if a hydrocarbon expert around here knows for sure.
Re: Blending TCW3 in diesel [Re: 32319] #5167392 07/21/19 03:29 PM
K
Online Content
K
Well I doubt you need a “hydrocarbon expert”. Once something is truly in solution it’s not going to separate.
I have a minor in chemistry, is that close enough?
1994 BMW 530i, 252K
