I have a 98 Expedition 5.4 4x4 with rear heat.
I am looking for a part number for the hose that comes from the tube off the back of the water pump to the heater core and splits to the line that feeds the rear heat.
I would like the quick connect fittings, since one of the connections is in a really tight spot. Plus I want to replace the entire hose due to my transmission fluid in cooling system problem and since this one connects to the tube behind the intake, I want to replace it before reinstalling the intake.
Here is a picture of the hose minus the quick connect fitting that goes to the heater core.
