Emblem Adhesive Recommendation
by Fitz98 - 02/26/20 07:18 PM
Drain Plug Washer Frozen to Oil Pan
by CrackyWainwright - 02/26/20 06:31 PM
ams OE 0/20 6100 mi 14 KIA 2.4L GDI
by pair of Blazers - 02/26/20 06:17 PM
Any Exotic Brand Dealership Mechanics Here?
by john_pifer - 02/26/20 06:14 PM
Sentra no start
by Aredeeem - 02/26/20 06:07 PM
Sync Update 2016 Cmax
by borgward - 02/26/20 03:30 PM
Kirkland 0w20 at local Costco
by paulri - 02/26/20 03:12 PM
LG Red in a VW DSG trans?
by racin4ds - 02/26/20 02:31 PM
2013 Jaguar XF 3.0 AWD
by ET16 - 02/26/20 02:25 PM
Ford....in trouble??
by earthbound - 02/26/20 01:31 PM
Interesting read
by double vanos - 02/26/20 10:51 AM
2010 Honda Element 127K miles valvetrain picture
by SLO_Town - 02/26/20 10:01 AM
Anyone Used a Sea Sucker Bike Rack/Mount?
by jcartwright99 - 02/26/20 09:46 AM
8 passenger vehicle typically 5 for <=$15k
by madRiver - 02/26/20 09:27 AM
RON Octane Gasoline rating
by Building3 - 02/26/20 09:26 AM
Who makes Canadian Supertech?
by Patman - 02/26/20 09:08 AM
Benefits of a hard break-in discussion
by buster - 02/26/20 08:54 AM
Scotts994Runner, Bu33leGutz, splitthebreak, shadango, JimNastic316
70808 Registered Users
116 registered members (AC1DD, 4WD, 2004tdigls, 2003f7, 14Accent, 97f150, 13 invisible), 2,044 guests, and 14 spiders.
Topics301,960
Posts5,206,392
Members70,808
Blending TCW3 in diesel #5163809 07/17/19 07:27 PM
3
32319 Offline OP
3
I'm not sure if this is the best forum to post this question but it seems OK.
I use off-road diesel in my old off-road engines. Tractor, mower, generator set. Until the most recent storage tank fill, my fuel guy has been able to deliver 500 ppm fuel to me. He's been unable to get more since my last delivery a few years ago. Now I have 15 ppm ULSD off-road fuel in my tank.
I always use 200:1 TCW3 in 15 ppm road fuel in my 6.5 TD truck but I mix in the oil when I fill at the pump.
I plan to use TCW3 in my new ULSD off-road fuel I have in my storage tank but I wonder if this oil goes into solution and remains in solution in a stationary tank without agitation. If I pour a gallon of TCW3 into 200 gallons of fuel, will I soon have one gallon of TCW3 laying in the bottom of the tank or will it blend and remain blended?
Thank you,
DW
Re: Blending TCW3 in diesel [Re: 32319] #5163908 07/17/19 09:58 PM
Chris142 Offline
I think it needs to be agitated to mix. Not much though. How big is the storage tank? Can you aerate it somehow with air?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Blending TCW3 in diesel [Re: 32319] #5164004 07/18/19 04:42 AM
varmint Offline
Use a clean 5 Gallon gas can, put in 1/2 gal of TCW3 and fill with diesel. Pour this into storage tank. Repeat with remaining TCW3.
You might want to do another 5 gal of diesel just to agitate or if you have an electric pump use nozzle in tank fill hole to agitate.
Re: Blending TCW3 in diesel [Re: varmint] #5164007 07/18/19 04:49 AM
varmint Offline
Forgot to add, when adding diesel to TCW3 in 5 gal can, put about 1 gal of diesel and shake can well before filling can with diesel.
Re: Blending TCW3 in diesel [Re: 32319] #5164192 07/18/19 09:22 AM
U
Ursatdx Offline
U
I use about a Qt of 2 stroke oil with each 50 gals diesel.
A bit of Biobor, too.
She loves it.
Cat 3116.
"If there must be trouble, let it be in my day, that my child may have peace." --- Thomas Paine
Re: Blending TCW3 in diesel [Re: 32319] #5164208 07/18/19 09:55 AM
R
rideahorse Offline
R
Why don't test it with a glass jar. Put diesel in first and then put a cap full of the tc3 in it without agitating it and see if it goes to the bottom.
Re: Blending TCW3 in diesel [Re: varmint] #5164235 07/18/19 10:31 AM
O
Oldmoparguy1 Offline
O
What is the deal with the counter weights on the wheels?
A Randomly Selected Thought For The Day:
If Noah had used Zip, he could have used a smaller boat.
Re: Blending TCW3 in diesel [Re: Oldmoparguy1] #5164236 07/18/19 10:34 AM
U
Ursatdx Offline
U
Not weights.
They protect components for the CTIS / Central Tire Inflation System.
You can inflate/deflate tire pressure on the fly or anytime using the engine driven
air compressor.
Re: Blending TCW3 in diesel [Re: 32319] #5164462 07/18/19 02:58 PM
3
32319 Offline OP
3
Thanks. I have 200 gallons in a 275 gallon IBC (tote) with a manual Fill-Rite piston pump. Not sure how I could aerate or agitate the fuel.
I guess I'll have to do it the hard way and do a 200:1 mix & separation test in a pickle jar and leave it sit to know if the oil comes out of solution. I'll probably end up having to mix in five gallon jugs and use it from there.
Re: Blending TCW3 in diesel [Re: 32319] #5164502 07/18/19 04:03 PM
H
hatt Offline
H
Totes have a large opening on top. You can use many things to mix its contents. Drill powered paddle mixer, boat oar, etc.
I use a couple to catch rainwater. I don't think I'd use them for long term fuel storage. The valve on the bottom looks pretty fragile. I'd worry about age.
2013 F150 5.0, Delo 400 XSP 5W-40, Wix 57502
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Blending TCW3 in diesel [Re: 32319] #5165172 07/19/19 09:17 AM
3
32319 Offline OP
3
My main concern is the oil falling out of solution over time.
No concern at all about keeping fuel in a tote. I've been doing that since 2004.
Re: Blending TCW3 in diesel [Re: 32319] #5165179 07/19/19 09:21 AM
K
kschachn Offline
K
I can't imagine that happening with two hydrocarbons.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Blending TCW3 in diesel [Re: kschachn] #5167379 07/21/19 02:19 PM
3
32319 Offline OP
3
Simple logic tells me the same thing. It would be nice if a hydrocarbon expert around here knows for sure.
Re: Blending TCW3 in diesel [Re: 32319] #5167392 07/21/19 02:29 PM
K
kschachn Offline
K
Well I doubt you need a “hydrocarbon expert”. Once something is truly in solution it’s not going to separate.
I have a minor in chemistry, is that close enough?
1994 BMW 530i, 252K
