Fram Xg3682 for ISO 32 🛠
by SavagePatch - 04/05/20 11:58 AM
Honda V6 PCV Valve - Steel Bolt
by SWS - 04/05/20 11:50 AM
Ford Fusion wiper blade question
by Corollaman - 04/05/20 11:05 AM
Is this stainless steel?
by atikovi - 04/05/20 10:45 AM
Skyactiv 2.5L - Oil Capacity
by buster - 04/05/20 10:42 AM
3/4" hose
by CNT - 04/05/20 10:29 AM
Westinghouse iGen 4500 Generator
by SailSkiDrive - 04/05/20 09:16 AM
Generac Power Washer Engine Oil Type.
by Andya - 04/05/20 08:49 AM
Barrs leak oil additive
by Micahmcmeen - 04/05/20 08:10 AM
Lawn mower oil question
by icemanrrc - 04/05/20 08:10 AM
Wait until you see who's driving...
by Shannow - 04/05/20 06:57 AM
Getting My Harley Back On The Road
by Silverado12 - 04/05/20 06:45 AM
Oil brand you've never used
by OilUzer - 04/05/20 02:27 AM
New dishwasher on order...
by gregk24 - 04/05/20 12:19 AM
Blueing steel
by koffy - 04/04/20 11:53 PM
Home electrical question.
by 73guna - 04/04/20 10:20 PM
daniell, carguy1701, London, Dave66, Kurt_Kent_09
71104 Registered Users
97 registered members (Ag76, 77GrandPrix, 007, 2015_PSD, 2009Edge, 4WD, 10 invisible), 2,712 guests, and 19 spiders.
Topics303,629
Posts5,238,673
Members71,104
98 Expedition Heater Hose - Need Identification #5163803 07/17/19 08:20 PM
F
Fitz98 Offline OP
F
I have a 98 Expedition 5.4 4x4 with rear heat.
I am looking for a part number for the hose that comes from the tube off the back of the water pump to the heater core and splits to the line that feeds the rear heat.
I would like the quick connect fittings, since one of the connections is in a really tight spot. Plus I want to replace the entire hose due to my transmission fluid in cooling system problem and since this one connects to the tube behind the intake, I want to replace it before reinstalling the intake.
Here is a picture of the hose minus the quick connect fitting that goes to the heater core.
[Linked Image]
Re: 98 Expedition Heater Hose - Need Identification [Re: Fitz98] #5163855 07/17/19 09:23 PM
M
mattwithcats Offline
M
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: 98 Expedition Heater Hose - Need Identification [Re: Fitz98] #5163947 07/18/19 12:32 AM
F
Fitz98 Offline OP
F
I saw those hoses on Rock Auto.
I was having troubles identifying by their picture whether this hose in the picture I showed is the input or output hose.
RA only has the Motorcraft inlet hose.
Re: 98 Expedition Heater Hose - Need Identification [Re: Fitz98] #5164022 07/18/19 06:16 AM
E
edwardh1 Offline
E
that sure is a complicated collection of connections, is it oem like that?
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: 98 Expedition Heater Hose - Need Identification [Re: edwardh1] #5164296 07/18/19 12:41 PM
F
Fitz98 Offline OP
F
Yes, that is how Ford did it on the Expedition with rear heat. One hose comes from the water pump (or the intake depending on whether it is supply or return), the T spits that with one hose going to the front heater core and the other connecting to tubes that feed the rear heater core.
Re: 98 Expedition Heater Hose - Need Identification [Re: Fitz98] #5164481 07/18/19 04:17 PM
1
1978elcamino Offline
1
looks expensive
