Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
Toyota to Mexico
by kstanf150 - 01/18/20 12:37 PM
Final Sludge Cleanup, HDEO - Diesel ??
by jssaab - 01/18/20 12:31 PM
A good cabin filter
by NH73 - 01/18/20 10:36 AM
K&N cut open.
by laserred96gt - 01/18/20 10:25 AM
Toyota Oem filter mileage
by Bettez88 - 01/18/20 10:22 AM
OCI, Owners manual versus oil Mfg.
by VQLT - 01/18/20 10:06 AM
MacBook Pro to Microsoft Surface
by Kira - 01/18/20 09:53 AM
Ford 5R55E Auxiliary Transmission Filter
by benjamming - 01/18/20 09:33 AM
Do all synthetic oils act as a cleaner?
by Loobit - 01/18/20 08:26 AM
Mobil 1 ESP now sold in 5qt jugs
by Patman - 01/18/20 08:12 AM
Mobil 1 Extended Performance Oil Filters
by jrommelt - 01/18/20 08:08 AM
These the same?
by Bettez88 - 01/18/20 06:53 AM
MaxLife SB 10w40 on Sale
by Mad_Hatter - 01/18/20 04:27 AM
Bebo77, 2EHA, jonnyb433, kzbd, 54Robert
70465 Registered Users
93 registered members (750IX, 2oldtommy, Armkb, atikovi, Aichiguy, 7 invisible), 2,462 guests, and 18 spiders.
Topics300,290
Posts5,172,538
Members70,465
Most Online3,728
Jan 11th, 2020
Preventative repair - 2009 Ford Flex water pump #5163526 07/17/19 01:56 PM
K
KGMtech Offline OP
K
Back in May I did the waterpump on the 2009 Flex, this was a preventative maintenance project, the internet being full of sad stories about failure of the Ford 3.5L V6 water pump, so I decided to tackle the job when the time suited me, versus how Mr. Murphy schedules this type of work.
The Flex had 206,600km when I started the process, no real evidence of any coolant loss, and oil remained clear - no milkshake colour tinges. The car has seen a good routine of maintenance, the Ford Plan covered the routine stuff for the first 5 years, and I've done the work since the Plan expired at 100,000km. I change the oil and filter at 6 month intervals which is usually 8k - 10k kilometres. I've used PP 5W20 and Motorcraft FL500S filters.
I purchased most of the Motorcraft parts from Village Ford in Michigan and had them shipped to my SIL in Florida, same for the special tools needed for this work (cam locks, harmonic balancer puller, etc.)
Rock Auto supplied valve cover gaskets, 2 drive belts. Parts and tools cost me about $900 CAD. A nice driving trip in April in my 2013 Maxima to Key West allowed me to stop off at SIL and get all my goodies :o)
The photos:
Valve cover beauty shot:
[Linked Image]20190717_141952_resized (2) by Ken McCandless, on Flickr
Old timing guides, showing virtually no wear, but put in new ones anyways..
[Linked Image]20190609_131636_resized by Ken McCandless, on Flickr
Deep inside the engine lies the ticking bomb? well this is a shot of the new pump secured for the next 10 years or so..
[Linked Image]20190605_163845_resized by Ken McCandless, on Flickr
Additional work included:
- new Motorcraft thermostat & gasket
- new Ford Specialty Green Coolant mixed with distilled water.
- Pennzoil Plat 5W20 and FL500 filter
- flushed the power steering fluid.
- new power steering stretch belt - Continental
- new serpentine belt - Continental.
The work took me an honest 29 hours to complete, I could shave 10 hours off if I had to do this again, but the space between the frame and engine is tight and cleaning and repeated practice for the installation of the big front cover added significantly to the time required. If I had removed the A/C hose on the passenger side of engine bay, I would have saved 5 hours, but then have spent more to restore functional system.
I paid for a subscription to AllData - I think this was money well spent.
The car now has 209,000km, with no leaks to report. The timing cover was a major pita to install with the special TA 357 sealant, the stuff skins over pretty fast and with the tight access I made some neighbours aware of my alternative vocabulary tongue2
Sad fact: the old water pump has virtually no play in bearing, it might have lasted another 5 years? duh
Added bonus: trick for installing the stretch belt: fasten the stretch belt to the small pulley with zip ties, cut a piece of 3M scotch brite green pad to fit a strip into the crank pulley at 12 o'clock, and wedge it while turning the crank clockwise. The extra friction of the Scotchbrite prevents the belt from slipping as you turn the crank clockwise. Spin the crank until the Scotchbrite is released and say "well that was easy!" cut off the zip ties from small pulley and sit back and thank me?
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Preventative repair - 2009 Ford Flex water pump [Re: KGMtech] #5163609 07/17/19 03:16 PM
L
Lubener Offline
L
Talk about a design nightmare. The engineers had to have been drinking when they decided where to place that water pump.
The "thinking" man's friend.
Re: Preventative repair - 2009 Ford Flex water pump [Re: KGMtech] #5163637 07/17/19 03:52 PM
bdcardinal Offline
I think it was more of a "we want this engine in this bay so make it happen" kind of thing. At least on the previous Duratec V6 engines where the pump was driven by a belt off the back of one of the cams, you could replace it without much fuss. Also the same 3.5 and 3.7 in the trucks is driven my a belt as are the 2.7EB engines no matter if they are mounted transverse or proper.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Preventative repair - 2009 Ford Flex water pump [Re: KGMtech] #5163665 07/17/19 04:29 PM
Z
zzyzzx Offline
Z
Ford uses a stretch belt?
Re: Preventative repair - 2009 Ford Flex water pump [Re: KGMtech] #5163674 07/17/19 04:46 PM
demarpaint Offline
Wow! As the saying went years ago, Ford has a better idea. Not in the case of this water pump though. FTR the engine internals look great!
God Bless Our Troops
Re: Preventative repair - 2009 Ford Flex water pump [Re: zzyzzx] #5163681 07/17/19 04:51 PM
bdcardinal Offline
Yup, my Mustang has one for the AC but I have the kit to delete it. There is a bolt hole on the timing cover for the tensionor used on F-150s.
Re: Preventative repair - 2009 Ford Flex water pump [Re: KGMtech] #5163707 07/17/19 05:24 PM
L
Lolvoguy Offline
L
Good work OP!
That job was the main reason I avoided going with a used Taurus.
Despite the time and aggravation, at least you know you never have to worry about it again during your ownership!
smile
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Preventative repair - 2009 Ford Flex water pump [Re: bdcardinal] #5163869 07/17/19 08:49 PM
T
The_Eric Offline
T
What is the purpose of adding a tensioner?
I actually remove them on all the truck LS based engines anymore and replace with a stretch belt. To me at least, it saves the customer money not replacing tensioner and I don't have worry about the wussy, low quality tensioner bearing fragging.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: Preventative repair - 2009 Ford Flex water pump [Re: The_Eric] #5163932 07/17/19 10:53 PM
bdcardinal Offline
The stretch belts on the Coyote engines have been theorized to be the cause of some low end noise by pulling too much on the crank pulley and therefore causing some accelerated wear on the main bearings.
Re: Preventative repair - 2009 Ford Flex water pump [Re: KGMtech] #5163978 07/18/19 01:28 AM
N
NothingNew Offline
N
Good going OP thumbsup
A good look at what this job entails:
Re: Preventative repair - 2009 Ford Flex water pump [Re: The_Eric] #5164085 07/18/19 06:50 AM
Z
zzyzzx Offline
Z
I think a one time use belt is extremely wasteful.
Re: Preventative repair - 2009 Ford Flex water pump [Re: KGMtech] #5321669 01/13/20 02:40 PM
K
kstanf150 Online Content
Online Content
K
Co-worker owns a 2010 Flex 3.5L with 191,000 miles. He’s facing a $1500 repair bill for a leaking water pump 😳
Crank case is full of coolant and thank goodness the computer went into limp mode before the engine overheated to the grenade stage. Great engine, but a horrible design!!!
Re: Preventative repair - 2009 Ford Flex water pump [Re: kstanf150] #5321701 01/13/20 03:13 PM
J
jcartwright99 Offline
J
Agree. It's a good engine that requires attention to water pump. However, the engineers have designed this to be an expensive repair. The water pump itself is not that expensive. These types of repairs drive customers insane. "My $100 waterpump will cost 1500 to install."
Re: Preventative repair - 2009 Ford Flex water pump [Re: KGMtech] #5321854 01/13/20 06:02 PM
super20dan Offline
would never buy car with this engine in the first place
99 silverado 5.3
2003 tundra v6
1981 toyota cressida wagon
2003 kia sorento
04 toyota highlander 4cyl 2013 toyota rav4
Re: Preventative repair - 2009 Ford Flex water pump [Re: KGMtech] #5321926 01/13/20 07:01 PM
K
Online Content
K
Probably not if your gona keep it forever and a day
But
If your gona drive it for 100K and trade
You’ll be fine
