Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
1994 Buick Century 63K miles
by MuzzleFlash40 - 02/19/20 07:33 PM
Why is this plug so expensive?
by motor_oil_madman - 02/19/20 07:01 PM
Mice and rat deterrent
by whizbyu - 02/19/20 06:45 PM
Gen Outlets Not Working
by coopns - 02/19/20 06:24 PM
Updated Motorcraft FL-2062-A
by advocate - 02/19/20 06:18 PM
7500hrs on the cummins
by motor_oil_madman - 02/19/20 06:11 PM
Is It Junk?
by yeehaw1960 - 02/19/20 05:49 PM
Dishwasher makes crackling noise
by jayjr1105 - 02/19/20 05:33 PM
what ceramic brake pads should i choose?
by apollo18 - 02/19/20 05:21 PM
school me on tint
by WhyMe - 02/19/20 04:27 PM
Michelin 7% Price Increase Effective 3/16/20
by Egg_Head - 02/19/20 03:58 PM
GunsInternational
by Yah-Tah-Hey - 02/19/20 03:39 PM
400hp VW Arteon confirmed for 2021
by wemay - 02/19/20 03:11 PM
redline 75W140
by mobilaltima - 02/19/20 02:50 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
134 registered members (77GrandPrix, 74Widebody, 14Accent, 4WD, 53' Stude, 55hambone, 13 invisible), 1,944 guests, and 23 spiders.
Topics301,675
Posts5,200,343
Members70,756
Scanner #5163420 07/17/19 11:36 AM
T
tiger862 Offline OP
T
Let me start off I have been out of business for years because of my body says so. Any way here is problem. Mother has 2012 Impala with what she said was ABS noise and violate shaking. Been diagnosed with bad wire, bearings, rotors etc. Now she is told it is now other side 😡 but will have to wait until they're not busy so just drive it. I need an ABS diagnosis so looking at scanners seem to be leaning towards the OTC 3210 for around 200. I could use it for airbag light on Altima that no one seems to remove as well as hopefully it will update to use on my 2018 Grand Caravan if I have problem down the road. Any other ideas around 200?
Tiger862
2018 Grand Caravan
Re: Scanner [Re: tiger862] #5163423 07/17/19 11:46 AM
W
Wolf359 Offline
W
I would suggest the Autel Diaglink. Has way more reviews. Also just $80.10 after you apply the 10% off coupon. Should do all systems like ABS and airbag. It's an extra $10 per car line so add an extra $20 for those two other brands.
https://www.amazon.com/Autel-Diaglink-Version-Diagnostic-Transmission/dp/B01N0QQZY7
Re: Scanner [Re: tiger862] #5163429 07/17/19 11:55 AM
L
LazyDog Offline
L
You might want to check the vin # for any recalls just in case something applies.
Re: Scanner [Re: tiger862] #5163492 07/17/19 01:21 PM
M
mk378 Online Content
Online Content
M
Is the ABS light on? This could simply be brake pads worn down to the metal or some other obvious mechanical problem.
Re: Scanner [Re: mk378] #5163499 07/17/19 01:29 PM
H
HangFire Offline
H
Exactly. Noise and violent shaking may be a case of brake shudder, maybe amplified by a loose bushing, end or joint.
Various musings: http://hangfire.net
Re: Scanner [Re: tiger862] #5163549 07/17/19 02:21 PM
T
tiger862 Offline OP
T
ABS and Trac light come on only when it does it. From what I am told most mornings going from reverse to drive will cause it as well as lots of stop and go will cause it. All lights remain off until these events happen then clear with in seconds. I glanced at it Saturday and from what I have seen drivers rotor is blue but free. This is why I need scanner that can initialize ABS module. Brakes just got replaced as part of problem. My gut is telling me a bad hose or bad electrical repair on ABS wire so if hose then a flush will be needed so ABS bleed is a good possibility. This is reason I was thinking OTC as most techs I know have the 3k OTC scanner.
Tiger862
2018 Grand Caravan
Re: Scanner [Re: tiger862] #5163877 07/17/19 08:56 PM
Dinoburner Online Content
Online Content
Have seen a rotor turn blue and cause shaking by a bad flex hose. Internal part of hose acts a a one way valve, that is it collapses.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: Scanner [Re: Dinoburner] #5163906 07/17/19 09:55 PM
T
tiger862 Offline OP
T
And that is my thinking. On that vehicle the bleed procedure can turn into nightmare if slightest air gets in system. I talked to her this evening and I informed her I won't do it without scanner handy. Still have leads to a scanner since I can't afford one right now (disability) so hopefully it come through.
Tiger862
2018 Grand Caravan
Re: Scanner [Re: tiger862] #5183047 08/09/19 04:35 PM
T
tiger862 Offline OP
T
I went with OBD dongle. I got one on eBay for less than 3.00. I hooked up to 2011 Kia Forte and used Car Scanner app which showed Air Bag had low voltage and since I just replaced battery I hit clear codes. Air Bag light is off now. I hooked my 18 Caravan and it only read engine data but I found a program to download if I need transmission information for 49.00 which I will eventually purchase if I can't find a free one.
Tiger862
2018 Grand Caravan
